Need to add Cisco Unified IP Phone 9951.
Answered Question
Jul 7th, 2010
I have a Cluster of Cisco Unified Communicatio Manager Version 7.0.2.20000-5  (Publisher and Subscriber) .
I have  Cisco Unified IP Phone 9951 and i want to add this.
Kindly Advise me how i can add this new cisco unified IP Phone 9951 in CUCM.
Best Regards
Jamil Hussain
Correct Answer by Ayodeji Okanlawon about 6 years 11 months ago
Jamil,
Your version of CCM ie CCM7.0 does not have a device pack for the 9900 series phones. You need the CCM 7.1upgrade DVD for this. After the upgrade you can then go to cco to dwonload the required patch. Please contact a skilled personel or a cisco partner if you do not have the skills to do this.
Correct Answer by j.ceron about 6 years 11 months ago
Overall Rating: 5 (2 ratings)
Rob Huffman Wed, 07/07/2010 - 06:20
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Jamil,
You will need 7.1(3a)su1 at a minimum
Cisco Unified IP Phone 8900 and 9900 Series
Before using the Cisco Unified IP Phone with Cisco Unified Communications Manager, you must install the latest firmware on all Cisco Unified Communications Manager servers in the cluster.
Note You can install Cisco Unified Communications Manager 7.1(3) or 7.1(3a). After you install one of these releases, you must install Cisco Unified Communications Manager*** 7.1(3a)su1. ***
https://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/7_1_3/cucm-rel_notes-713a.html#wp1754557
Cheers!
Rob
Jamil Hussain Wed, 07/07/2010 - 06:26
Yes 9951 is not available as a phone model on CUCM 7.0.2.
I need to upgrade CUCM or Device Package.
And if i need to upgrade first i need to install  7.1(3)  and then 7.1(3a)su1.
Please reply
Best Regards
Jamil Hussain
Jamil Hussain Wed, 07/07/2010 - 09:56
Hi Rob
I need to Purchase 7.1(3a)su1 or I can download it from software section from cisco.com.
And also one more thing i have a running environment well during upgrade it will affect my previous confugration ?
j.ceron Thu, 07/08/2010 - 21:07
We have CM 8.0. when We tryed to add 9951 phone it also doesnt appear in phone list.  what we need to put this phone in device list ?
Juan Carlos
Jamil Hussain Sat, 07/10/2010 - 09:05
Hi Ceron.
Could you please tell me the procedure for adding 9951 Phone in the device list.
How to add the phone in device List.
Jamil Hussain Mon, 07/12/2010 - 00:16
Does it supports same for Cisco unified Communication Manager Version 7.0.2.20000-5.
Jamil Hussain
Correct Answer
Ayodeji Okanlawon Mon, 07/12/2010 - 06:04
    2017 IP Telephony
Jamil,
Jamil Hussain Mon, 07/12/2010 - 06:36
Dear aokanlawon
Thanks for your reply.
I was just confirming about the device package if its supporting  in CM Version 7.0.
Otherwise i can handle this task.
Jamil Hussain
Jamil Hussain Fri, 07/16/2010 - 13:30
Hi Good day to all
I have successfully upgraded CUCM 7.1(3)su1.
I have switched the version to new but received this error message after upgrading.Before i have uploaded the licence file for system and it was 2 one for PUBLISHER AND ONE FOR SUBSCRIBER.
Phone License Feature is ok but CCM Node License  Status is Showing Missing
Licensing Warnings:
System is operating on insufficient licenses. Please upload additional license files.
I have attached the snapshot for licence report.
Please advise.
Jamil Hussain Fri, 07/23/2010 - 06:17
Hi all
I have successfully upgrade CUCM to 7.1(3a)Su1 From 7.0.
Now i am able to see the option for Cisco Unified IP Phone 9951 but when i added the phones i got error message on Phone " Unable To Connect".
I check the device default Configuration and found in the Load information of 9951 AND 9971 IS EMPTY.
I am not able to register my phone because of LOAD INFORAMTIN is empty.
Kindy assist me to sort out this issue.
Waiting for a favourable reply.
Regards,,,
