Serial Numbers with CiscoWorks LMS 3.2
Answered Question
Hi all,
Is there a way to find the Serial Numbers of all your Cisco devices using CiscoWorks LMS 3.2?
Thanks in advance,
Carles
Correct Answer by Joel Monge about 7 years 2 weeks ago
You can run a hardware report under RME > Reports > Report Generator > Inventory > Hardware Report.  However, some devices are not aware of their serial number electronically.  In these cases, you can add the serial number using the "snmp-server chassis id" command so that RME can pick it up.  You can check this link with details on how the serial number is obtained via SNMP.
Overall Rating: 5 (1 ratings)
Correct Answer
Joel Monge Wed, 07/07/2010 - 08:13
  • Cisco Employee,
