SIP Trunk between CUCM 7.x and CCCM 5.x
Jul 7th, 2010
Is it possible to create a SIP Trunk ( Not ICT) between 2 Call manager servers present in 2 different networks with routing enabled between them. If Yes,
could someone help with its configuration.
Thanks in Advance
Overall Rating: 3 (2 ratings)
Adrian Saavedra Wed, 07/07/2010 - 08:02
Yes. Here you can find General Deployment Considerations for SIP Trunks:
Here you can find information for configuration:
Why you want to use SIP?. ICT H.323 is the simplest way to communicate CM clusters.
Hope it helps, if it does please rate.
Kind regards,
- Adrian.
Jaime Valencia Wed, 07/07/2010 - 09:13
I agree with Adrian, while it's technically possible to create a SIP trunk between 2 CUCMs, the highest level of compatibility and features is achieved by using an ICT non-GK controlled
Any particular reason to do SIP over an ICT?
If this helps, please rate
abraham23482 Wed, 07/07/2010 - 11:00
Management decided to go with SIP trunk between the 2 clusters thats why.
I made it work somehow... Thanks both of you..
marcoaurrutia Wed, 07/07/2010 - 11:50
Hi Abrahm
I recommend you that use the ICT (non-gatekeepr), for this conecction between this CM,
go to Gateway/Trunk/ICT,
