clear isakmp sa
Jul 7th, 2010
Cannot re-establish VPN connection after peer ip address change.  It connected successfully for a few hours and then dropped.  What does the "clear isakmp sa" command do?  If I execute the command, will I need to add the VPN commands back into the configuration?
Diego Armando C... Wed, 07/07/2010 - 10:18
  • Bronze, 100 points or more
That's is only going to clear the Security Association. That is NOT going to clear your config.
