Inter Cluster Trunk issue
Jul 7th, 2010
I have a non gatekeeper controlled inter cluster trunk configured between 2 clusters A and B.
Cluster A i have Publisher and Subscriber , and in cluster B i have publisher only.
ICT Configuration :
                             Cluster A                          Cluster B
Primary CCM
        publisher ip B                     publisher ip A
Secondary CCM                                            subscriber ip A
When publisher ip A is down i am unable to make calls between Cluster B and Cluster A
What is the reason, although publisher ip B can ping subscriber ip A.
Brandon Buffin Wed, 07/07/2010 - 13:33
  • Purple, 4500 points or more
In ICT configuration, do you have both server IP addresses configured (pub/sub in cluster B)?
Hope this helps.
Brandon
SJ SJ Wed, 07/07/2010 - 14:01
yes in cluster B  ict configuration i have the ip addresses of pub and sub of cluster A.
Adrian Saavedra Wed, 07/07/2010 - 14:16
  • Gold, 750 points or more
Hello SJ SJ,
Check if the CM Group configured in the DevicePool in cluster A ICT contains the same servers defined as remote CM servers in cluster B ICT.
Kind regards,
- Adrian.
