default gateway
Answered Question
Jul 7th, 2010
in a vlan generally we go for the first ip as the gateway for ex
172.16.0.0 - network, gateway will be 172.16.0.1 can we have 172.16.0.254 as the gateway
the reason is we have a vlan 172.21.0.0 with 172.21.0.1 gateway we want to subnet it but one of the server ip address is 172.21.1.1 and we dont want to change server ip address so if we create a vlan 172.21.1.0/24  the gateway will be 172.21.1.1 but we have a server with ip address so we are trying to keep the gateway as 172.21.1.254..i have tried yet so please let me know it is possible or not
karthik
Correct Answer by Ganesh Hariharan about 7 years 2 weeks ago
karthik
Hi karthik,
You can use 172.21.1.254 as default gateway for the vlan, As genral practice for designing in network .1 ip is selected as vip or gateway for vlans.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Correct Answer by Nagaraja Thanthry about 7 years 2 weeks ago
You can certainly have 172.16.0.254 as the default gateway. The default gateway IP is chosen per your convenience.
Overall Rating: 5 (2 ratings)
Correct Answer
Nagaraja Thanthry Wed, 07/07/2010 - 16:22
  • Cisco Employee,
karthikeyan gop... Fri, 07/09/2010 - 11:10
Thanks for the reply I got the needed information
Karthik G
Network Administrator
Correct Answer
Ganesh Hariharan Wed, 07/07/2010 - 22:18
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
karthik
Hi karthik,
Hope to Help !!
Ganesh.H
Karthik G
