cucm 6.1
htluo Wed, 07/07/2010 - 20:09
  • Red, 2250 points or more
You should upgrade to CUCM 7.x.
Then you may configure mobile connect (a.k.a. Single Number Reach) with time of day schedule.  So any call to your IP phone will ring your home phone in specific schedule.
Check SRND (design guide): http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/mobilapp.html#wp1045872
On CUCM 6.1, you may configure mobile connect.  But you won't be able to configure ring schedule.
Michael
http://htluo.blogspot.com
maharris Wed, 07/07/2010 - 20:58
  • Silver, 250 points or more
I think if you did a translation pattern that was in a partition that was only reachable after 5, and the regular phone partition was not, and you did a called party transform mask to his home number, it would probably work.  But, then he would have to depend on home voicemail after hours, if he could not take the call.
Mary Beth
