ReRouting IPSec traffic on the hub ASA
Jul 7th, 2010
I have a hub location "A" and two braches "B" and "C", both connected to "A" using IPSec tunnels on ASA 5505 v8.0.
The question is: Can I reroute traffic coming from "B" to "C"?
"B"  --IPSec-->  "A"  --IPSec-->  "C"
Federico Coto F... Wed, 07/07/2010 - 19:39
Hi Guido,
Yes, the ASA allows hairpinning the traffic back out the same interface in which it receives it.
Assuming that both tunnels end on the outside interface, then normally you need:
same-security-traffic permit intra-interface
Also, the correct routing and NAT rules for the traffic.
Let us know if you need further help.
