Cannot Access ASDM in Management interface
Jul 7th, 2010
Just wonder why I cannot access ASDM from management interface of Cisco ASA 5520 considering that there is preconfigured ip address in the management interface 0/0 (factory default). When I type (management 0/0) ASDM site and will promt to install ASDM but after entering the username and password there is a message malformed.
How can I solve this issue?
thank you and best regards.
KARUPPUCHAMY MA... Wed, 07/07/2010 - 23:46
There is no issue with firewall.. You need to check your JAVA version.
I hope there is some issue with your java installation on your local pc
Nagaraja Thanthry Thu, 07/08/2010 - 05:59
What version of ASDM you are running? Depending upon the Java compatiblity could change. Here is a document that outlines Java requirements for 6.0(3) ASDM version.
Similarly, every ASDM version will have such compatibility information. I would suggest you look into those and check your Java version.
Hope this helps.
