Private line emulation on uC500/CME does not generate CDR
Jul 8th, 2010
Hi all, I have a customer who has the following configuration in his UC500 to simulate a private line.
router#show running-config
voice-port 1/0/0
connection plar-opx 6230001
dial-peer voice 82 pots
destination-pattern 82
port 1/0/0
ephone-dn 10
number 1010
name manager
ephone-dn 11
number 6230001
name private-line
trunk 82
ephone 1
button 1:10 2:11
This works as expected, when the manager selects line 2 he gets his private line can can place calls to the CO. the problem is that calls from this private number generate call detail records with no dialed number. I have replicated this in a lab with a cisco 1700 router running cme 4.1 and the effect is the same. When the radius call detail records are examined the dialed number is totally absent. I may be wrong, but I think this may be an oversight by Cisco, but I need confirmation and if so, some idea as to when there may be a fix.
A workaround solution may be to find another way to emulate private line operation on CME without using the "trunk xx" command. Any ideas how this may be accomplished?
Thank you.
