Video via Inter-Cluster Trunk (Non-Gatekeeper Controlled) with Media Termination Point Required
Answered Question
Jul 8th, 2010
Hi Outthere,
We've tow CUCM Cluster connected via a Inter-Cluster Trunk (Non-Gatekeeper Controlled). We use the Option Media Termination Point Required.
An Cisco IOS Enhanced Software Media Termination Point works on both sides.
For audio-calls everything works fine!
Now we want to use video-call.
The MTP is in passthrough mode.
Regions und Locations are also conigured.
What else do we need and what are the options to troubleshoot it?
Correct Answer by Jaime Valencia about 6 years 6 months ago
Cisco Unified CM Release 5.0 introduced audio transcoding resources  based on Cisco IOS Enhanced Media Termination Point, which are able to  support transcoding the audio stream of a video call while still  supporting the video stream via a pass-through codec. The pass-through  codec is used only for the video stream because the pass-through codec  cannot be used for a stream that requires transcoding. The following  three conditions must all be true for the pass-through codec to be used:
The two endpoint devices have a  matching CODEC capability.
MTP Required is not checked for either endpoint.
All intermediate resource devices (MTPs  and transcoders) support the pass-through codec.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/6x/video.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (1 ratings)
martin1.plank Thu, 07/08/2010 - 02:27
Sorry I forgot some interresting details:
CUCM System version: 6.1.4.2228-1
MTP: Voice Router with Cisco IOS Software, 2800 Software (C2800NM-IPVOICEK9-M), Version 12.4(24)T3
dspfarm profile 9 mtp
description MTP for ICT passthrough and G729r8
codec pass-through
codec g729r8
maximum sessions software 100
associate application SCCP
Correct Answer
Jaime Valencia Thu, 07/08/2010 - 06:49
java
