Core to multisite VPN project
abelleli71
Hi there
Have a project for configure 1 core BULIDING ( an Hospital ) and 50 Branches ( Pharmacy )
Need to Implement A MultipVPN environment with the following requirment :
1. The core VPN Must have multilink capabilites ( 2 or 3 different HDSL lines ) Eg. VPN Concentrator 3000 ?
2. The branches Must have multilink capabilites Eg. Cisco 1720 or Cisco RV016
Is it possible ?
With 50 branches, I think the recommendation will be DMVPN.
You can also have plain IPsec or IPsec/GRE tunnels if using routers.
The equipment that you mentioned is EoS.
You should look for using ASAs or routers for this.
Federico.
Thanks for the answer Federico
We use to works with REFURBISHED HW so doesn 't matter if its EOS .
Consider that we have DLINK RV016 on each branch. ( and cannot change it )
The only question is .. Which HW has got the Head quarter ?
VPN 3000
ASA
or what else ?
