Filtering Multiple Auth Users in SawMill
Jul 8th, 2010
I am unable to generate a report with more than a single person. The only attributes I am applying is:
Statistics for 01/Jun/2010 - 30/Jun/2010, 30 days
Report is filtered and shows data for
  Action is NOT: TCP_DENIED
  Auth User is: local\[email protected], local\[email protected] (<<These are applied as "Wildcard Expression")
With a single user, I can generate a report without issue but the second I add another user the report is blank. At this point it is all or just 1. I know I have sucessfully done this in the past but now it is not working.
allscott Fri, 07/09/2010 - 07:15
Easiest way is to add more indivudal items per field type query rather than trying to build a more complex argument within a single element.
For example:
Hope this helps
Related Content
