SPA509G - Paper Labels
Hi All,
Just wondering if their is a 'nice' way to go about making use of the four buttons with the paper labels on the SPA509G.  I've used the 7931 and found a nice little template thats a word document that allows you to print out users names.  Very clean and very nice.
The SPA509Gs 4 buttons and label seems out of place.  Does anyone use these?
klogata Thu, 07/08/2010 - 08:15
Here is one that I created. Please let me know if it works for you or if there are changes needed.
(edited to attach correct file - previous file was SPA501G label - sorry)
Patrick Born Fri, 03/18/2011 - 07:15
Other templates that Kerry developed are here:
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman","serif";} One reference document to locate SPA phone resources
