Admin Login
Answered Question
Jul 8th, 2010
I have to standardize all of our switches and routers and some of them
have username and login password right after the banner and some of
don't. what commands can i use to make all of them ask for a username
and password.I have an example below of what i'm talking about
attached below.The example is what i want all the switches to look like
Correct Answer by jonathanaxford about 6 years 9 months ago
Hi Scooter
Try the following command:
username admin privelege 15 password PASSWORD
Then apply the login local command to the VTY lines and console line:
line vty 0 4
login local
Hope this helps,
Jonathan
Overall Rating: 5 (1 ratings)
Correct Answer
jonathanaxford Thu, 07/08/2010 - 08:12
  • Bronze, 100 points or more
Hi Scooter
line vty 0 4
login local
Hope this helps,
Jonathan
darren-carr Thu, 07/08/2010 - 15:51
Scooter817
Would you not consider using AAA on your switches (if this is possible), to reduce the admin overhead? Use RADIUS or TACACS, makes it much easier to administer a big group of switches? With a local login as a fallback?
I use this method in my environment. We make use of the full AAA model, and can report on connectivity, etc.
Very easy to implement.
