How to archieve configuration in ciscoworks for 4404 wireless controller
Answered Question
Jul 8th, 2010
Hi All,
How can we archieve configuration in ciscoworks for 4404 wireless controller.
Thanks in advance.
Samir
Correct Answer by Joe Clarke about 6 years 7 months ago
The WCS controllers are supported just like any other device.  Make sure you have either telnet or SSH enabled for config archive transport, then before a Sync Archive on your controllers.  RME will log into them, and run "show running-config" to extract the configuration.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Thu, 07/08/2010 - 16:36
