Failure to console to the MeetingPlace 3515 Media Server
Jul 8th, 2010
Hi All,
I have misplaced my Terminal Cable to console to the Meetingplace 3515 Media Server, mp-3515ms-av250.
I built one using the cable pinout provided by docwiki.cisco.com:
To Chassis (DB-9 Male)FunctionTo PC Terminal (DB-9 Female)
TXD
RXD
GND
My cable is tested to be OK, however, i'm getting no response from the device.
Has anyone faced a similar problem?
iantra123 Mon, 03/07/2011 - 06:30
Try with this:
Signal Name
Side 1
Side 2Signal
TD (Transmit Data)32RD
RD (Receive Data)23TD
RTS (Request to Send)78CTS
CTS (Clear To Send)87RTS
SG (Signal Ground)55SG
DSR (Data Set Ready)64DTR
CD ( Carrier Detect)14DTR
DTR (Data Terminal Ready)41CD
DTR(Data Terminal Ready)46DSR
There are no more document, but if Cisco says that it's a null modem cable, then it's a "full" null modem cable.
Not the 235 pinout only.
Antra
Related Content
