SIP Hookflash not working on FXS for invoking Supp Services
Jul 8th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
thanks for taking a look.....
Hookflash for supplimentary services using Application, Service DSAPP is not working...
Have 2 problems:
1:
If I make an outbound call from FXS phone to  PSTN I can get secondary dial tone....
If I receive call from PSTN to FXS phone, I  cannot initiate hookflash to get secondary dial tone.  I hear the cliks and in the debug vpm all trace i cann see the hookflash occuring but as said cannot get secondary dial tone.  Thoughts on problem 1 appreciated.
2:
The other things thats failing is that when an outbound call is made and  hookflash is invoked I can get secondary dial tone, a second call can then be made  but when the calls transfer is attempted to transfer the call either by blind or consult, nothing happens...For some reason a conference appears to  work....
Any ideas as to what is happening greatly appreciated....
thanks in advance...and look forward to hearing from you with any ideas......
Paul
On FXS ports on VG887 gateway for Supplementary services....
Base config is as follows:
application
service dsapp
  param dialpeer 101
  param disc-toggle-time 30
  param callWaiting TRUE
  param callConference TRUE
  param callTransfer TRUE
  param blind-xfer-wait-time 10
voice-port 0
compand-type a-law
cptone GB
timing hookflash-in 200 75
station-id number +441635698816
caller-id enable
dial-peer voice 101 voip
destination-pattern .T
session protocol sipv2
session target dns:FQDN
voice-class codec 1
dtmf-relay sip-notify rtp-nte sip-kpml
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback cisco !
dial-peer voice 10 pots
service dsapp
destination-pattern +441635698816
port 0
authentication username [email protected] 7 00321C02055D04080A70
auppal Sat, 07/10/2010 - 09:34
  • Cisco Employee,
for any application to run it needs to be triggered inbound. Can you have service dsapp on the voip dialpeer it matches inbound to see if that fixes the issue. else get deb ccsip messages, deb voip ccapi inout, deb vpm signal
thanks
paul_savage Mon, 07/12/2010 - 01:47
Thanks for the reply,
when I enabled Application, DSAPP glagablly i was able to get supplimentary services for call on hold/call retrieval, call waiting and 3 part call conference.
What i can't seem to do however is blind transfer or consult transfer...
I will try and get some time later today and get some debugs for anyone to review..
thanks for takinbg the time to review....as always, appreciated.
