is this a spanning-tree issue or VTP pruning issue?
I've run in to a problem i cant figure out. Its a live environment and I must be careful not to make things worse, things are working mostly.... I have a link between 2 switches, trunk - dot1q,  on one end everything looks fine on the opposite end things don't look right.  Things have been working until a couple of weeks ago no changes have been made.
The trunk  is NOT carrying all the Vlans (except Vlan 1), when I check spanning-tree it show s the port forwarding all the Vlans.  This switch is configured as VTP client, v2, prunning enabled and the down stream switch is transparent.
Any suggestions? thanks inadvance.
show trunk 4/1 detail
* - indicates vtp domain mismatch
# - indicates dot1q-all-tagged enabled on the port
$ - indicates non-default dot1q-ethertype value
Port      Mode         Encapsulation  Status        Native vlan
4/1      nonegotiate  dot1q          trunking      1
Port      Peer-Port  Mode         Encapsulation  Status
4/1      FastEther  unknown      unknown        unknown
Port      TrunkFramesTx         TrunkFramesRx         WrongEncap
4/1                 119731770              63985591           0
Port      Vlans allowed on trunk
4/1      1,34,157,166,172,175,178,190,194,504,637,652,804-805,864
Port      Vlans allowed and active in management domain
Port      Vlans in spanning tree forwarding state and not pruned
4/1      1
show spantree 4/1
Port                     Vlan Port-State    Cost      Prio Portfast Channel_id
4/1                     1    forwarding           19   32 disabled 0
4/1                     34   forwarding           19   32 disabled 0
4/1                     157  forwarding           19   32 disabled 0
4/1                     166  forwarding           19   32 disabled 0
4/1                     172  forwarding           19   32 disabled 0
4/1                     175  forwarding           19   32 disabled 0
4/1                     178  forwarding           19   32 disabled 0
4/1                     190  forwarding           19   32 disabled 0
4/1                     194  forwarding           19   32 disabled 0
4/1                     504  forwarding           19   32 disabled 0
4/1                     637  forwarding           19   32 disabled 0
4/1                     652  forwarding           19   32 disabled 0
4/1                     804  forwarding           19   32 disabled 0
4/1                     805  forwarding           19   32 disabled 0
4/1                     864  forwarding           19   32 disabled 0
Chetan Kumar Ress Thu, 07/08/2010 - 10:45
  • Silver, 250 points or more
Can you post trunk config of both switches
Chetan Kumar
This is the down stream switch, where everything looks fine. - Version 12.1(22)EA12, 2950
interface FastEthernet0/26
switchport trunk allowed vlan 1,34,157,166,172,175,178,190,194,504,637,652,804
switchport trunk allowed vlan add 805,864
switchport mode trunk
switchport nonegotiate
end
This is a 6509 with cat OS, Version NmpSW: 8.4(2a)
set trunk 4/1  nonegotiate dot1q 1,34,157,166,172,175,178,190,194,504,637,652,804-805,864
clear trunk 4/1  2-33,35-156,158-165,167-171,173-174,176-177,179-189,191-193,195-503,505-636,638-651,653-803,806-863,865-4094
If there is anything else please do not hesitate.
Regards.
Chetan Kumar Ress Thu, 07/08/2010 - 11:28
Hi Sean
I think that you had post the output of 6509 ( in intial post ) .
Can you try to configure your 2950 with encap dot1q ( switch port trunk encap dot1q ).
Note : Default it will use Dot1q but before configuring please check the output of 2950 with sh int fa0/26 trunk )
You supposed to see the encap dot1q .
Brelow output :
fa0/20       on           802.1q         trunking      10
and also please check the log in 2950 switch.
Chetan Kumar
Sorry I should have posted this at the begining:
show int fa0/26 trunk
Fa0/26      on           802.1q         trunking      1
Fa0/26      1,34,157,166,172,175,178,190,194,504,637,652,804-805,864
show spanning-tree int fa0/26
Vlan             Role Sts Cost      Prio.Nbr Type
VLAN0001         Root FWD 19        128.26   P2p
VLAN0034         Root FWD 19        128.26   P2p
VLAN0157         Root FWD 19        128.26   P2p
VLAN0166         Root FWD 19        128.26   P2p
VLAN0172         Root FWD 19        128.26   P2p
VLAN0175         Desg FWD 19        128.26   P2p
VLAN0178         Root FWD 19        128.26   P2p
VLAN0190         Root FWD 19        128.26   P2p
VLAN0194         Desg FWD 19        128.26   P2p
VLAN0504         Root FWD 19        128.26   P2p
VLAN0637         Root FWD 19        128.26   P2p
VLAN0652         Root FWD 19        128.26   P2p
VLAN0804         Root FWD 19        128.26   P2p
VLAN0805         Root FWD 19        128.26   P2p
VLAN0864         Desg FWD 19        128.26   P2p
As you can see the 2950 seems ready to go, it just seems that the 6509 is not forwarding the vlans!
I'm suspecting vtp pruning on the 6509, and the 2950 is transparent.
show vtp domain
Version      : running VTP2 (VTP3 capable)
Domain Name  : XXXXXX                           Password  : configured
Notifications: disabled                         Updater ID: ###.###.###.###
Feature        Mode           Revision
VLAN           Client         XXX
Pruning             : enabled
VLANs prune eligible: 2-1000
Chetan Kumar Ress Thu, 07/08/2010 - 12:04
===> As you mention 2950 is transparent but in output is it showing VTP Client.
Can you explain ?
Regrads
Chetan Kumar
Sorry my bad. I wasn't clear - 6509 is client and 2950 is transparent -
2950
show vtp status
VTP Version                     : 2
Configuration Revision          : 0
Maximum VLANs supported locally : 250
Number of existing VLANs        : 19
VTP Operating Mode              : Transparent
VTP Domain Name                 : XXXXX
VTP Pruning Mode                : Enabled
VTP V2 Mode                     : Enabled
VTP Traps Generation            : Disabled
MD5 digest                      : XXXXXXXXXXXXXXXXXXXXXXXXXXXX
Configuration last modified by ###.###.###.### at 6-21-10 18:29:17
ResTow>
6509
show vtp domain
Domain Name  : XXXXX                           Password  : configured
VLAN           Client         146
Pruning             : enabled
That makes it a bit clearer - sorry
