TCP ports used by Cisco IPS
Answered Question
Jul 8th, 2010
I have have searched high and low via Google and within cisco.com for the answer to this, but can not seem to find it documented anywhere.  I am attempting to identify all ports that are required to manage the a Cisco IPS so that I can open up the firewalls.  It is my understanding that the ports below are required, but I am not sure if I am missing anything, please see below:
TCP 22:     Source => Sensor Admin
TCP 443:   Source => Sensor Admin
UDP 123:  Sensor Admin => NTP Server
Am I missing anything?  Thank you!
Jonathan
Boulder, Co
Correct Answer by Christopher Dreier about 6 years 9 months ago
Additionally, if you plan to use SNMP, you will need to allow UDP/161 and UDP/162 between the sensor and your management station.
Thank you,
Blayne Dreier
Cisco TAC IDS Team
**Please check out our Podcast**
TAC Security Show: http://www.cisco.com/go/tacsecuritypodcast
Correct Answer by Scott Fringer about 6 years 9 months ago
Jonathon;
  If you will be making use of automatic updates for signatures and global correlation updates you will also need to allow the IPS management IP address access on TCP 80 (signature and GC updates) and UDP 53 (GC updates).
Scott
Overall Rating: 5 (2 ratings)
Correct Answer
Scott Fringer Thu, 07/08/2010 - 09:56
  • Cisco Employee,
Jonathon;
Scott
Correct Answer
Christopher Dreier Thu, 07/08/2010 - 12:21
  • Silver, 250 points or more
Thank you,
Blayne Dreier
Cisco TAC IDS Team
Jonathan Grant Thu, 07/08/2010 - 12:45
Thank you gentlemen, that answers my question.  Have a GREAT day!
Jonathan
Boulder, Co
Related Content
