Nexus1000V and mac-pinning
Answered Question
Jul 8th, 2010
I have configured mac-pinning. How can I see in Nexus which VEthernet interface is pinned to which Ethernet-NIC ?  I didn't find it.
This is our used nx-version: 4.0(4)SV1(3)
Hendrik
Correct Answer by lwatta about 6 years 6 months ago
To show the pinning you need to query the VEM module. You can do this directly on the ESX host via vemcmd on the command line or you can remotely query the VEM from the VSM.
From the VSM run the following command.
n1000v-MV# module vem 5 execute vemcmd show port
  LTL    IfIndex   Vlan    Bndl  SG_ID Pinned_SGID  Type  Admin State  CBL Mode   Name
    6          0      1 T     0     32          32  VIRT     UP    UP    0  Trunk vns
    8          0   3969       0     32          32  VIRT     UP    UP    1 Access
    9          0   3969       0     32          32  VIRT     UP    UP    1 Access
   10          0      2       0     32           1  VIRT     UP    UP    1 Access
   11          0   3968       0     32          32  VIRT     UP    UP    1 Access
   12          0      2       0     32           2  VIRT     UP    UP    1 Access
   13          0      1       0     32          32  VIRT     UP    UP    0 Access
   14          0   3967       0     32          32  VIRT     UP    UP    1 Access
   15          0   3967       0     32          32  VIRT     UP    UP    1 Access
   16          0      1 T     0     32          32  VIRT     UP    UP    1  Trunk arp
   18   25010040      1 T   305      1          32  PHYS     UP    UP    1  Trunk vmnic1
   19   25010080      1 T   305      2          32  PHYS     UP    UP    1  Trunk vmnic2
  305   16000004      1 T     0     32          32  CHAN     UP    UP    1  Trunk
Find your vmnic interfaces.and in the output and cross reference with the SG_ID column. Here you can see that vmnic1 is SGID 1 and vmnic2 is SGID 2
Next find the line with your VM and cross reference with the Pinned_SGID column. The number in that column will be either 1 or 2. If it's 1 then the VM is pinned to vmnic1 and 2 would mean vmnic2
louis
Overall Rating: 4 (2 ratings)
thilo schueler-mach Wed, 11/10/2010 - 15:19
hello,
after more then one hour I stop searching for a solution on nexus. So if you configure pinning manually, the assignments are readable in the config. If you choose automatic assignment by cdp, have a look at the mac-address-table interface x/y on the connected physical switch. There you can find the mac address from all vm`s which use this uplink.
regards
Thilo
Correct Answer
lwatta Thu, 11/11/2010 - 04:57
  • Cisco Employee,
louis
