Using CUE with CM 7.0 (ccm-manager credentials hidden)
diegorgarces
Hi all,
I have a Central Office with Call Manager 7.1 and a branch with CUE 7.0.4. In my Branch have the following:
se-10-122-217-10# show ccn status ccm-manager
JTAPI Subsystem is not registered with any Call Manager
I think is because i need to configure
ccn subsystem jtapi
ctiport 8601 8602 8603 8604
ccm-manager address 10.122.140.100
ccm-manager credentials hidden XXXX
end subsystem
Can somebody hel me using the command ccm-manager credentials hidden XXXX
XXXX= username + password jtapi? encrypted?
What can i do to encrypted this, which tool can i use?
Best Regards
Brandon Buffin
In the CUE GUI, go to Configure > Callmanager. You should be able to enter the JTAPI username/password in an unencrypted format from here.
Hope this helps.
Brandon
