Cisco DMP 4400g with Samsung 460TSn
joberhaus
I have seen the list of supported touch screen monitors for the Cisco DMP 4400g, but I thought I would ask if anyone knows if the DMP will work with the Samsung 460TSn.  The Samsung 460TSn is an ideal monitor for conference rooms because it is just like the Cisco LCD except it is already touch screen enabled and it runs Windows XP built in.  The 460TSn documentation says the touch screen mode is infrared (IR).  I assume this would be an ideal setup for anyone with a conference room and it would be amazing if I could bring the touch capabilities to the DMP.
Tomas de Leon
The Samsung Display should work for Normal Display operations.
The TOUCH feature is NOT supported.
Which Touch driver does the Samsung Display use?
supported info can be found here:
http://www.cisco.com/en/US/prod/collateral/video/ps9339/ps7220/data_sheet_c78-480272.html
Touchscreen support
Vendor
Supported Systems
3M
Touch Sensor and Systems:
3M MicroTouch ClearTek II touch sensor
3M MicroTouch System SCT3250CX
3M MicroTouch Sensor SCT7650
3M MicroTouch System SCT3250SX
3M MicroTouch Capacitive TouchSense System
3M MicroTouch DST touch system
Display Systems:
3M MicroTouch Display M1500SS (15 in.)
3M MicroTouch Display M1700SS (17 in.)
3M MicroTouch CT150 15-in. LCD Touch Monitor
3M MicroTouch ChassisTouch 17-in. LCD Touch Monitor
ELO
All Acoustic Pulse Recognition systems
Zytronics
Zybrid Screen systems
General Touch
All systems supported by the ST6001S controller
I hope this helps!
Cheers!
T.
