My route-map does not send vlan traffic on a appropriate interface
Hello for everyone
Please help me.
I have this problem scenario:
The router Cisco 2851 with c2800nm-advipservicesk9-mz.124-19.bin.
Several VLAN’s have been configured on the router:
Dasha#sh vlan-switch
VLAN Name                             Status    Ports
1    default                          active    Fa0/1/0, Fa0/1/1, Fa0/1/2
                                                Fa0/1/3
2    VLAN0002                         active
3    VLAN0003                         active
4    VLAN0004                         active
10   VLAN0010                         active    Fa0/0/0
20   VLAN0020                         active    Fa0/0/2
30   VLAN0030                         active
40   VLAN0040                         active    Fa0/0/1
100  VLAN0100                         active
151  VLAN0151                         active
155  fl-guest                         active    Fa0/0/3
200  VLAN0200                         active
207  VLAN0207                         active
1002 fddi-default                     active
1003 token-ring-default               active
1004 fddinet-default                  active
1005 trnet-default                    active
The router is one of the several other routers in my WAN network. It is connected to other router (R1) through VPN Site-to-Site over GRE for access to main Internet service provider (ISP1). All Cisco 2851 VLAN’s is going to the Internet through R1. All except VLAN 155 fl-guest that is intended to go to reserve (back up) ISP2. This ISP2 is directly connected to the Cisco 2851 that I’m talking about.
I think it can be done by route-map. I have configured my Cisco 2851 for the route-map.  I see policy routing matches but users in VLAN 155 cannot access Internet through ISP2. And I cannot ping 8.8.8.8 source vlan 155.
Below I present config parts of the Cisco 2851 and some show outputs. If you need more information, please tell me.
VLAN 155
Interface                  IP-Address      OK? Method Status                Protocol
Vlan155                    10.8.0.1        YES manual up                    up
Dasha#sh run | b interface Vlan155
interface Vlan155
ip address 10.8.0.1 255.255.255.0
ip nat inside
ip nat enable
ip virtual-reassembly
ip policy route-map fl-guest
Dasha#sh run | b interface FastEthernet0/0/3
description fl-guest
switchport access vlan 155
Dasha#ping 8.8.8.8 source vlan 155
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Packet sent with a source address of 10.8.0.1
Success rate is 0 percent (0/5)
VLAN 20
Vlan20                     [global ip addr]   YES NVRAM  up                    up
Dasha#sh run | b interface Vlan20
interface Vlan20
description --=== Internet "Sputnik" ===--
ip address [global ip addr] 255.255.255.252
ip access-group FILTER_TO_INTERNET out
no ip redirects
no ip proxy-arp
ip nat outside
ip nat enable
crypto map dynamic-l2tp
Dasha#sh run | b interface FastEthernet0/0/2
description --== SPUTNIK ==--
switchport access vlan 20
Dasha#ping 8.8.8.8 source vlan 20
Packet sent with a source address of 80.122.174.90
Success rate is 100 percent (5/5), round-trip min/avg/max = 312/314/316 ms
NAT and ACL
ip nat inside source list NAT_TO_SPUTNIK interface Vlan20 overload
ip access-list extended FILTER_TO_INTERNET
permit tcp 10.2.0.0 0.0.3.255 any eq www
permit ip 10.8.0.0 0.0.0.255 any log
permit tcp 10.2.0.0 0.0.3.255 any eq 443
permit tcp 10.2.0.0 0.0.3.255 any eq ftp
permit tcp 10.2.0.0 0.0.3.255 any eq ftp-data
permit udp 10.2.0.0 0.0.3.255 any eq ntp
permit tcp 10.2.0.0 0.0.3.255 any eq 8080
permit tcp 10.4.0.0 0.0.3.255 any eq www
permit tcp 10.4.0.0 0.0.3.255 any eq 443
permit tcp 10.4.0.0 0.0.3.255 any eq ftp
permit tcp 10.4.0.0 0.0.3.255 any eq ftp-data
permit udp 10.4.0.0 0.0.3.255 any eq ntp
permit tcp 10.4.0.0 0.0.3.255 any eq 8080
permit tcp 10.2.4.0 0.0.3.255 any eq 443
permit tcp 10.2.4.0 0.0.3.255 any eq ftp
permit tcp 10.2.4.0 0.0.3.255 any eq ftp-data
permit udp 10.2.4.0 0.0.3.255 any eq ntp
permit tcp 10.2.4.0 0.0.3.255 any eq 8080
ip access-list extended NAT_TO_SPUTNIK
deny   ip 10.2.0.0 0.0.3.255 10.4.0.0 0.0.0.255
deny   ip 10.4.0.0 0.0.3.255 10.2.0.0 0.0.0.255
deny   ip 10.2.0.0 0.0.3.255 10.2.4.0 0.0.0.255
deny   ip 10.2.4.0 0.0.0.255 10.2.0.0 0.0.3.255
deny   ip 10.2.4.0 0.0.0.255 10.4.0.0 0.0.0.255
permit ip 10.2.0.0 0.0.3.255 any
permit ip 10.4.0.0 0.0.3.255 any
permit ip 10.2.4.0 0.0.0.255 any
PBR
access-list 101 permit ip 10.8.0.0 0.0.0.255 any
route-map fl-guest permit 10
match ip address 101
set ip default next-hop 80.122.174.89 80.122.174.90
set default interface Vlan20 FastEthernet0/0/2
Also I tried different other variations with set command.
Dasha#sh route-map
route-map fl-guest, permit, sequence 10
  Match clauses:
    ip address (access-lists): 101
  Set clauses:
  Policy routing matches: 1447 packets, 121185 bytes
With kind regards
Sergey Bondarenko
skype: sergio.bondarenko
ICQ: 435 129 759
sergey.bondarenko.grey@gmail.com
I think there is a single ICMP entry for 80.122.174.90 in your nat table which is bind to 10.8.0.1.
Can you try either to clear it and then ping from your laptop or try something else from your laptop like http or telnet
Laurent.
8 Replies 8
Laurent Aubert
By default, a policy-map doesn't apply to packets locally generated by the router. You need to add the following command:
ip local policy route-map fl-guest
Also here is the config you should use:
set ip next-hop 80.122.174.89
This way VLAN 155 will use ISP2 until the VLAN interface get down.
Laurent.
Thank you for your answer Laurent.
I have implemented your proposed commands. And now I can ping through ISP2 with source of 10.8.0.1 (VLAN 155 address).
But when I connect my notebook to the router Ethernet port to which VLAN 155 is assigned (switchport access vlan155) I receive ip addr from dhcp server and gateway 10.8.0.1. And I cannot ping even 10.8.0.1.
From the router I cannot ping ip addr of my notebook (10.8.0.2).
What do you think about it?
The route-map you applied on VLAN155 allow you to bypass the routing table for routing decision. So each packet received on VLAN155 will be send to ISP2 regardless the destination so what you see is expected.
Can you browse the Internet ? It should work.
If you want to be able locally ping between your device and router, you need to be more granular in your route-map ACL by denying any traffic which destination is 10.8.0.0/24 subnet so the routing table will be used instead.
Laurent.
Hello Laurent
Thanks for your hint about ACL.
I have edited my ACL so now it looks:
Dasha#sh access-lists 101
Extended IP access list 101
    5 deny ip any 10.8.0.0 0.0.0.255 (1382 matches)
    10 permit ip 10.8.0.0 0.0.0.255 any (39364 matches)
And now I can ping my notebook (10.8.0.2) from the router and backwards.
But unfortunately I cannot ping 8.8.8.8 from my notebook (10.8.0.2) that is in VLAN 155.
Here I present the debug ip policy output:
Dasha#, len 100, policy rejected -- normal forwarding
Jul 10 08:39:20.421: IP: s=10.8.0.2 (Vlan155), d=8.8.8.8, len 62, FIB policy match
Jul 10 08:39:20.421: IP: s=10.8.0.2 (Vlan155), d=8.8.8.8, g=80.122.174.89, len 62, FIB policy routed
Jul 10 08:39:20.421: IP: s=10.8.0.2 (Vlan155), d=8.8.8.8, len 62, policy match
Jul 10 08:39:20.421: IP: route map fl-guest, item 10, permit
Jul 10 08:39:20.421: IP: s=10.8.0.2 (Vlan155), d=8.8.8.8 (Vlan20), len 62, policy routed
Jul 10 08:39:20.421: IP: Vlan155 to Vlan20 80.122.174.89
Jul 10 08:39:20.837: IP: s=192.168.1.2 (local), d=192.168.1.220, len 52, policy rejected -- normal forwarding
Dasha#terminal monitor
Jul 10 08:39:20.869: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:21.309: IP: s=192.168.1.2 (local), d=192.168.1.1, len 600, policy rejected -- normal forwarding
Jul 10 08:39:21.309: IP: s=192.168.1.2 (local), d=192.168.1.1, len 156, policy rejected -- normal forwarding
Jul 10 08:39:21.309: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:21.421: IP: s=10.8.0.2 (Vlan155), d=8.8.8.8, len 62, FIB policy match
Jul 10 08:39:21.421: IP: s=10.8.0.2 (Vlan155), d=8.8.8.8, g=80.122.174.89, len 62, FIB policy routed
Jul 10 08:39:21.421: IP: s=10.8.0.2 (Vlan155), d=8.8.8.8, len 62, policy match
Jul 10 08:39:21.421: IP: route map fl-guest, item 10, permit
Jul 10 08:39:21.421: IP: s=10.8.0.2 (Vlan155), d=8.8.8.8 (Vlan20), len 62, policy routed
Jul 10 08:39:21.421: IP: Vlan155 to Vlan20 80.122.174.89
Jul 10 08:39:21.513: IP: s=80.122.174.90 (local), d=66.223.219.48, len 40, policy rejected -- normal forwarding
Jul 10 08:39:21.541: IP: s=192.168.1.2 (local), d=192.168.1.1, len 40, policy rejected -- normal forwarding
Jul 10 08:39:21.661: IP: s=192.168.1.2 (local), d=192.168.1.1, len 108, policy rejected -- normal forwarding
Jul 10 08:39:22.037: IP: s=10.8.0.2 (Vlan155), d=10.1.0.1, len 48, FIB policy match
Jul 10 08:39:22.037: IP: s=10.8.0.2 (Vlan155), d=10.1.0.1, g=80.122.174.89, len 48, FIB policy routed
Jul 10 08:39:22.037: IP: s=10.8.0.2 (Vlan155), d=10.1.0.1, len 48, policy match
Jul 10 08:39:22.037: IP: route map fl-guest, item 10, permit
Jul 10 08:39:22.037: IP: s=10.8.0.2 (Vlan155), d=10.1.0.1 (Vlan20), len 48, policy routed
Jul 10 08:39:22.037: IP: Vlan155 to Vlan20 80.122.174.89
Jul 10 08:39:22.309: IP: s=192.168.1.2 (local), d=192.168.1.1, len 600, policy rejected -- normal forwarding
Dasha#terminal mon, len 444, policy rejected -- normal forwarding
Jul 10 08:39:22.313: IP: s=192.168.1.2 (local), d=192.168.1.220, len 100, policy rejected -- normal forwarding
Jul 10 08:39:22.337: IP: s=192.168.1.2 (local), d=192.168.1.1, len 40, policy rejected -- normal forwarding
Jul 10 08:39:22.337: IP: s=192.168.1.2 (local), d=192.168.1.1, len 204, policy rejected -- normal forwarding
Jul 10 08:39:22.341: IP: s=192.168.1.2 (local), d=192.168.1.1, len 236, policy rejected -- normal forwarding
Jul 10 08:39:22.341: IP: s=192.168.1.2 (local), d=192.168.1.1, len 348, policy rejected -- normal forwarding
Jul 10 08:39:22.341: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:22.345: IP: s=192.168.1.2 (local), d=192.168.1.1, len 348, policy rejected -- normal forwarding
Jul 10 08:39:22.345: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:22.349: IP: s=192.168.1.2 (local), d=192.168.1.1, len 348, policy rejected -- normal forwarding
Jul 10 08:39:22.349: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:22.357: IP: s=192.168.1.2 (local), d=192.168.1.39, len 100, policy rejected -- normal forwarding
Jul 10 08:39:22.369: IP: s=192.168.1.2 (local), d=192.168.1.1, len 156, policy rejected -- normal forwarding
Jul 10 08:39:22.369: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:22.373: IP: s=192.168.1.2 (local), d=192.168.1.1, len 108, policy rejected -- normal forwarding
Jul 10 08:39:22.437: IP: s=192.168.1.2 (local), d=192.168.1.4, len 52, policy rejected -- normal forwarding
Jul 10 08:39:22.577: IP: s=192.168.1.2 (local), d=192.168.1.1, len 40, policy rejected -- normal forwarding
Jul 10 08:39:22.585: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:22.725: IP: s=80.122.174.90 (local), d=80.122.174.89, len 64, policy rejected -- normal forwarding
Jul 10 08:39:22.725: IP: s=172.17.0.10 (local), d=172.17.0.9, len 64, policy rejected -- normal forwarding
Jul 10 08:39:22.725: IP: s=172.16.0.6 (local), d=172.16.0.5, len 64, policy rejected -- normal forwarding
Jul 10 08:39:22.817: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:23.061: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:23.173: IP: s=192.168.1.2 (local), d=192.168.1.30, len 52, policy rejected -- normal forwarding
Jul 10 08:39:23.261: IP: s=192.168.1.2 (local), d=192.168.1.162, len 100, policy rejected -- normal forwarding
Jul 10 08:39:23.309: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:23.345: IP: s=192.168.1.2 (local), d=192.168.1.1, len 600, policy rejected -- normal forwarding
Jul 10 08:39:23.345: IP: s=192.168.1.2 (local), d=192.168.1.1, len 460, policy rejected -- normal forwarding
Jul 10 08:39:23.349: IP: s=192.168.1.2 (local), d=192.168.1.1, len 188, policy rejected -- normal forwarding
Jul 10 08:39:23.353: IP: s=192.168.1.2 (local), d=192.168.1.1, len 252, policy rejected -- normal forwarding
Dasha#terminal m, len 348, policy rejected -- normal forwarding
Jul 10 08:39:23.353: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:23.353: IP: s=192.168.1.2 (local), d=192.168.1.1, len 348, policy rejected -- normal forwarding
Jul 10 08:39:23.357: IP: s=192.168.1.2 (local), d=192.168.1.1, len 348, policy rejected -- normal forwarding
Jul 10 08:39:23.357: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:23.361: IP: s=192.168.1.2 (local), d=192.168.1.1, len 348, policy rejected -- normal forwarding
Jul 10 08:39:23.361: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:23.361: IP: s=192.168.1.2 (local), d=192.168.1.1, len 332, policy rejected -- normal forwarding
Jul 10 08:39:23.365: IP: s=192.168.1.2 (local), d=192.168.1.1, len 348, policy rejected -- normal forwarding
Jul 10 08:39:23.365: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:23.369: IP: s=192.168.1.2 (local), d=192.168.1.1, len 348, policy rejected -- normal forwarding
Jul 10 08:39:23.369: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:23.373: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:23.373: IP: s=192.168.1.2 (local), d=192.168.1.1, len 140, policy rejected -- normal forwarding
Jul 10 08:39:23.373: IP: s=192.168.1.2 (local), d=192.168.1.1, len 108, policy rejected -- normal forwarding
Jul 10 08:39:23.421: IP: s=10.8.0.2 (Vlan155), d=8.8.8.8, len 62, FIB policy match
Jul 10 08:39:23.421: IP: s=10.8.0.2 (Vlan155), d=8.8.8.8, g=80.122.174.89, len 62, FIB policy routed
Jul 10 08:39:23.449: IP: s=10.8.0.2 (Vlan155), d=8.8.8.8, len 62, policy match
Jul 10 08:39:23.449: IP: route map fl-guest, item 10, permit
Jul 10 08:39:23.449: IP: s=10.8.0.2 (Vlan155), d=8.8.8.8 (Vlan20), len 62, policy routed
Jul 10 08:39:23.449: IP: Vlan155 to Vlan20 80.122.174.89
Jul 10 08:39:23.541: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:23.849: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:23.993: IP: s=192.168.1.2 (local), d=192.168.1.7, len 100, policy rejected -- normal forwarding
Jul 10 08:39:24.369: IP: s=192.168.1.2 (local), d=192.168.1.1, len 600, policy rejected -- normal forwarding
Jul 10 08:39:24.369: IP: s=192.168.1.2 (local), d=192.168.1.1, len 476, policy rejected -- normal forwarding
Jul 10 08:39:24.385: IP: s=192.168.1.2 (local), d=192.168.1.1, len 40, policy rejected -- normal forwarding
Jul 10 08:39:24.385: IP: s=192.168.1.2 (local), d=192.168.1.1, len 156, policy rejected -- normal forwarding
Jul 10 08:39:24.385: IP: s=192.168.1.2 (local), d=192.168.1.1, len 268, policy rejected -- normal forwarding
Jul 10 08:39:24.389: IP: s=192.168.1.2 (local), d=192.168.1.1, len 348, policy rejected -- normal forwarding
Jul 10 08:39:24.389: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:24.393: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Dasha#terminal n, len 348, policy rejected -- normal forwarding
Jul 10 08:39:24.397: IP: s=192.168.1.2 (local), d=192.168.1.1, len 348, policy rejected -- normal forwarding
Jul 10 08:39:24.397: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:24.421: IP: s=192.168.1.2 (local), d=192.168.1.1, len 348, policy rejected -- normal forwarding
Jul 10 08:39:24.421: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:24.429: IP: s=192.168.1.2 (local), d=192.168.1.1, len 348, policy rejected -- normal forwarding
Jul 10 08:39:24.429: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:24.433: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:24.433: IP: s=192.168.1.2 (local), d=192.168.1.1, len 300, policy rejected -- normal forwarding
Jul 10 08:39:24.433: IP: s=192.168.1.2 (local), d=192.168.1.1, len 124, policy rejected -- normal forwarding
Jul 10 08:39:24.581: IP: s=192.168.1.2 (local), d=192.168.1.7, len 52, policy rejected -- normal forwarding
Jul 10 08:39:24.633: IP: s=192.168.1.2 (local), d=192.168.1.1, len 40, policy rejected -- normal forwarding
Jul 10 08:39:24.645: IP: s=192.168.1.2 (local), d=192.168.1.30, len 100, policy rejected -- normal forwarding
Jul 10 08:39:24.917: IP: s=192.168.1.2 (local), d=192.168.1.4, len 100, policy rejected -- normal forwarding
Jul 10 08:39:25.029: IP: s=192.168.1.2 (local), d=192.168.1.39, len 52, policy rejected -- normal forwarding
Jul 10 08:39:25.161: IP: s=192.168.1.2 (local), d=192.168.1.8, len 100, policy rejected -- normal forwarding
Jul 10 08:39:25.317: IP: s=192.168.1.2 (local), d=192.168.1.1, len 108, policy rejected -- normal forwarding
Jul 10 08:39:25.353: IP: s=192.168.1.2 (local), d=10.1.0.237
Dasha#terminal no , len 118, policy rejected -- normal forwarding
Jul 10 08:39:25.369: IP: s=192.168.1.2 (local), d=10.1.0.237, len 119, policy rejected -- normal forwarding
Jul 10 08:39:25.397: IP: s=192.168.1.2 (local), d=10.1.0.237, len 118, policy rejected -- normal forwarding
Jul 10 08:39:25.413: IP: s=192.168.1.2 (local), d=10.1.0.237, len 121, policy rejected -- normal forwarding
Jul 10 08:39:25.421: IP: s=192.168.1.2 (local), d=192.168.1.1, len 600, policy rejected -- normal forwarding
Jul 10 08:39:25.421: IP: s=192.168.1.2 (local), d=192.168.1.1, len 300, policy rejected -- normal forwarding
Jul 10 08:39:25.441: IP: s=192.168.1.2 (local), d=192.168.1.1, len 348, policy rejected -- normal forwarding
Jul 10 08:39:25.441: IP: s=192.168.1.2 (local), d=192.168.1.1, len 400, policy rejected -- normal forwarding
Jul 10 08:39:25.445: IP: s=192.168.1.2 (local), d=192.168.1.1, len 348, policy rejected -- normal forwarding
Jul 10 08:39:25.445: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:25.449: IP: s=192.168.1.2 (local), d=192.168.1.1, len 348, policy rejected -- normal forwarding
Jul 10 08:39:25.449: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:25.449: IP: s=192.168.1.2 (local), d=192.168.1.1, len 332, policy rejected -- normal forwarding
Jul 10 08:39:25.453: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:25.457: IP: s=192.168.1.2 (local), d=192.168.1.1, len 348, policy rejected -- normal forwarding
Jul 10 08:39:25.457: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:25.457: IP: s=192.168.1.2 (local), d=192.168.1.1, len 156, policy rejected -- normal forwarding
Jul 10 08:39:25.457: IP: s=192.168.1.2 (local), d=192.168.1.1, len 124, policy rejected -- normal forwarding
Jul 10 08:39:25.461: IP: s=192.168.1.2 (local), d=10.1.0.237, len 118, policy rejected -- normal forwarding
Jul 10 08:39:25.541: IP: s=192.168.1.2 (local), d=192.168.1.1, len 108, policy rejected -- normal forwarding
Jul 10 08:39:25.765: IP: s=192.168.1.2 (local), d=192.168.1.1, len 108, policy rejected -- normal forwarding
Jul 10 08:39:25.957: IP: s=192.168.1.2 (local), d=192.168.1.162, len 52, policy rejected -- normal forwarding
Jul 10 08:39:26.245: IP: s=192.168.1.2 (local), d=10.1.0.237, len 122, policy rejected -- normal forwarding
Jul 10 08:39:26.261: IP: s=192.168.1.2 (local), d=10.1.0.237, len 122, policy rejected -- normal forwarding
Jul 10 08:39:26.273: IP: s=192.168.1.2 (local), d=10.1.0.237, len 122, policy rejected -- normal forwarding
Jul 10 08:39:26.289: IP: s=192.168.1.2 (local), d=10.1.0.237, len 122, policy rejected -- normal forwarding
Jul 10 08:39:26.305: IP: s=192.168.1.2 (local), d=10.1.0.237, len 121, policy rejected -- normal forwarding
Jul 10 08:39:26.321: IP: s=192.168.1.2 (local), d=10.1.0.237, len 119, policy rejected -- normal forwarding
Jul 10 08:39:26.349: IP: s=192.168.1.2 (local), d=10.1.0.237, len 115, policy rejected -- normal forwarding
Jul 10 08:39:26.453: IP: s=192.168.1.2 (local), d=192.168.1.1, len 600, policy rejected -- normal forwarding
Jul 10 08:39:26.453: IP: s=192.168.1.2 (local), d=192.168.1.1, len 428, policy rejected -- normal forwarding
Jul 10 08:39:26.505: IP: s=192.168.1.2 (local), d=192.168.1.1, len 40, policy rejected -- normal forwarding
Jul 10 08:39:26.509: IP: s=192.168.1.2 (local), d=192.168.1.1, len 220, policy rejected -- normal forwarding
Dasha#terminal no , len 348, policy rejected -- normal forwarding
Jul 10 08:39:26.509: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:26.513: IP: s=192.168.1.2 (local), d=192.168.1.1, len 348, policy rejected -- normal forwarding
Jul 10 08:39:26.513: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:26.517: IP: s=192.168.1.2 (local), d=192.168.1.1, len 348, policy rejected -- normal forwarding
Jul 10 08:39:26.517: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:26.521: IP: s=192.168.1.2 (local), d=192.168.1.1, len 332, policy rejected -- normal forwarding
Jul 10 08:39:26.525: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:26.525: IP: s=192.168.1.2 (local), d=192.168.1.1, len 348, policy rejected -- normal forwarding
Jul 10 08:39:26.529: IP: s=192.168.1.2 (local), d=192.168.1.1, len 348, policy rejected -- normal forwarding
Jul 10 08:39:26.529: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:26.533: IP: s=192.168.1.2 (local), d=192.168.1.1, len 348, policy rejected -- normal forwarding
Jul 10 08:39:26.533: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:26.541: IP: s=192.168.1.2 (local), d=192.168.1.1, len 348, policy rejected -- normal forwarding
Jul 10 08:39:26.541: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:26.553: IP: s=192.168.1.2 (local), d=192.168.1.1, len 348, policy rejected -- normal forwarding
Jul 10 08:39:26.553: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:26.573: IP: s=192.168.1.2 (local), d=192.168.1.1, len 300, policy rejected -- normal forwarding
Jul 10 08:39:26.577: IP: s=192.168.1.2 (local), d=192.168.1.1, len 124, policy rejected -- normal forwarding
Jul 10 08:39:26.777: IP: s=192.168.1.2 (local), d=192.168.1.1, len 40, policy rejected -- normal forwarding
Jul 10 08:39:26.989: IP: s=192.168.1.2 (local), d=192.168.1.39, len 100, policy rejected -- normal forwarding
Jul 10 08:39:27.001: IP: s=192.168.1.2 (local), d=192.168.1.8, len 88, policy rejected -- normal forwarding
Jul 10 08:39:27.249: IP: s=192.168.1.2 (local), d=192.168.1.220, len 100, policy rejected -- normal forwarding
Jul 10 08:39:27.421: IP: s=10.8.0.2 (Vlan155), d=8.8.8.8, len 62, FIB policy match
Jul 10 08:39:27.421: IP: s=10.8.0.2 (Vlan155), d=8.8.8.8, g=80.122.174.89, len 62, FIB policy routed
Jul 10 08:39:27.421: IP: s=10.8.0.2 (Vlan155), d=8.8.8.8, len 62, policy match
Jul 10 08:39:27.421: IP: route map fl-guest, item 10, permit
Jul 10 08:39:27.421: IP: s=10.8.0.2 (Vlan155), d=8.8.8.8 (Vlan20), len 62, policy routed
Jul 10 08:39:27.421: IP: Vlan155 to Vlan20 80.122.174.89
Jul 10 08:39:27.513: IP: s=80.122.174.90 (local), d=66.223.219.48, len 40, policy rejected -- normal forwarding
Jul 10 08:39:27.577: IP: s=192.168.1.2 (local), d=192.168.1.1, len 600, policy rejected -- normal forwarding
Jul 10 08:39:27.577: IP: s=192.168.1.2 (local), d=192.168.1.1, len 300, policy rejected -- normal forwarding
Jul 10 08:39:27.593: IP: s=192.168.1.2 (local), d=192.168.1.1, len 332, policy rejected -- normal forwarding
Jul 10 08:39:27.597: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:27.597: IP: s=192.168.1.2 (local), d=192.168.1.1, len 348, policy rejected -- normal forwarding
Jul 10 08:39:27.601: IP: s=192.168.1.2 (local), d=192.168.1.1, len 348, policy rejected -- normal forwarding
Jul 10 08:39:27.601: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:27.601: IP: s=192.168.1.2 (local), d=192.168.1.1, len 332, policy rejected -- normal forwarding
Jul 10 08:39:27.605: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:27.605: IP: s=192.168.1.2 (local), d=192.168.1.1, len 348, policy rejected -- normal forwarding
Jul 10 08:39:27.609: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:27.609: IP: s=192.168.1.2 (local), d=192.168.1.1, len 348, policy rejected -- normal forwarding
Jul 10 08:39:27.613: IP: s=192.168.1.2 (local), d=192.168.1.1, len 332, policy rejected -- normal forwarding
Jul 10 08:39:27.613: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:27.617: IP: s=192.168.1.2 (local), d=192.168.1.1, len 348, policy rejected -- normal forwarding
Jul 10 08:39:27.617: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:27.621: IP: s=192.168.1.2 (local), d=192.168.1.1, len 348, policy rejected -- normal forwarding
Jul 10 08:39:27.621: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:27.625: IP: s=192.168.1.2 (local), d=192.168.1.1, len 332, policy rejected -- normal forwarding
Jul 10 08:39:27.625: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:27.629: IP: s=192.168.1.2 (local), d=192.168.1.1, len 348, policy rejected -- normal forwarding
Jul 10 08:39:27.629: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:27.629: IP: s=192.168.1.2 (local), d=192.168.1.1, len 40, policy rejected -- normal forwarding
Jul 10 08:39:27.633: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:27.641: IP: s=192.168.1.2 (local), d=192.168.1.1, len 332, policy rejected -- normal forwarding
Jul 10 08:39:27.645: IP: s=192.168.1.2 (local), d=192.168.1.1, len 108, policy rejected -- normal forwarding
Jul 10 08:39:27.645: IP: s=192.168.1.2 (local), d=192.168.1.1, len 348, policy rejected -- normal forwarding
Jul 10 08:39:27.645: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:27.649: IP: s=192.168.1.2 (local), d=192.168.1.1, len 348, policy rejected -- normal forwarding
Jul 10 08:39:27.649: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:27.661: IP: s=192.168.1.2 (local), d=192.168.1.1, len 332, policy rejected -- normal forwarding
Jul 10 08:39:27.661: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:27.661: IP: s=192.168.1.2 (local), d=192.168.1.1, len 348, policy rejected -- normal forwarding
Jul 10 08:39:27.665: IP: s=192.168.1.2 (local), d=192.168.1.1, len 348, policy rejected -- normal forwarding
Jul 10 08:39:27.665: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:27.669: IP: s=192.168.1.2 (local), d=192.168.1.1, len 332, policy rejected -- normal forwarding
Jul 10 08:39:27.669: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Dasha#terminal no monitor
Jul 10 08:39:27.669: IP: s=192.168.1.2 (local), d=192.168.1.1, len 348, policy rejected -- normal forwarding
Jul 10 08:39:27.673: IP: s=192.168.1.2 (local), d=192.168.1.1, len 348, policy rejected -- normal forwarding
Jul 10 08:39:27.673: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:27.681: IP: s=192.168.1.2 (local), d=192.168.1.1, len 348, policy rejected -- normal forwarding
Jul 10 08:39:27.681: IP: s=192.168.1.2 (local), d=192.168.1.1, len 384, policy rejected -- normal forwarding
Jul 10 08:39:27.681: IP: s=192.168.1.2 (local), d=192.168.1.1, len 92, policy rejected -- normal forwarding
Jul 10 08:39:27.685: IP: s=192.168.1.2 (local), d=192.168.1.1, len 348, policy rejected -- normal forwarding
I can traceroute 8.8.8.8 from the router VLAN 155 (10.8.0.1 addr).
And the packets go directly from  80.122.174.89.
Dasha#traceroute 8.8.8.8 source 10.8.0.1
Tracing the route to 8.8.8.8
  1 80.122.174.89 4 msec 0 msec 0 msec
  2 10.0.2.123 620 msec 552 msec 560 msec
  3 10.0.2.1 580 msec 576 msec 552 msec
  4 10.255.0.25 588 msec 572 msec 568 msec
  5 172.17.66.85 596 msec 560 msec 548 msec
  6 195.3.118.185 572 msec 556 msec 560 msec
  7 195.3.68.14 588 msec 604 msec
    195.3.68.18 608 msec
  8 72.14.218.172 568 msec 620 msec 568 msec
  9 72.14.238.44 576 msec
    72.14.238.46 596 msec 616 msec
10 209.85.250.140 [MPLS: Label 595403 Exp 4] 576 msec
    209.85.248.182 [MPLS: Label 557649 Exp 4] 592 msec
    209.85.250.140 [MPLS: Label 595403 Exp 4] 572 msec
11 72.14.233.114 644 msec
    64.233.175.246 608 msec 584 msec
12 72.14.239.197 580 msec
    72.14.239.199 572 msec
    209.85.255.143 584 msec
13  *  *  *
14 8.8.8.8 608 msec 620 msec 616 msec
Route-map is matched also
Dasha#sh route-map
  Match clauses:
  Set clauses:
  Policy routing matches: 14681 packets, 1079100 bytes
Dasha#ping 8.8.8.8 source 10.8.0.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 612/622/644 ms
Dasha#sh route-map
  Match clauses:
  Set clauses:
  Policy routing matches: 14686 packets, 1079600 bytes
If you need more information please let me know.
With kind regards
Sergey Bondarenko
e-mail and jabber: sergey.bondarenko.grey@gmail.com
With kind regards
Sergey Bondarenko
Hmm everything looks fine... Could you remove your outbound ACL and crypto-map and check again. Also verify NAT is working properly.
Laurent.
Hello Laurent
I think my nat behaves abnormally.
Please look on the debug.
I have connected my notebook (ip addr 10.8.0.2) to VLAN 155 and ping 8.8.8.8. I cannot rich the network.
I ping 8.8.8.8 source Vlan 155 (ip addr 10.8.0.1) directly from the router CLI. Ping success rate is 100%.
Jul 14 10:37:05.717: NAT: s=10.8.0.2->80.122.174.90, d=8.8.8.8 [1985]
.Jul 14 10:37:05.717: NAT: s=10.8.0.1, d=80.122.174.90->10.8.0.2 [54538]!
.Jul 14 10:37:06.717: NAT: s=10.8.0.2->80.122.174.90, d=8.8.8.8 [1986]
.Jul 14 10:37:06.717: NAT: s=10.8.0.1, d=80.122.174.90->10.8.0.2 [54578]
.Jul 14 10:37:07.625: NAT: s=10.8.0.1->80.122.174.90, d=8.8.8.8 [61018]!!
.Jul 14 10:37:07.721: NAT: s=10.8.0.2->80.122.174.90, d=8.8.8.8 [1987]
.Jul 14 10:37:07.721: NAT: s=10.8.0.1, d=80.122.174.90->10.8.0.2 [54642]
.Jul 14 10:37:08.213: NAT*: s=8.8.8.8, d=80.122.174.90->10.8.0.1 [20543]
.Jul 14 10:37:08.213: NAT: s=10.8.0.1->80.122.174.90, d=8.8.8.8 [61019]!
.Jul 14 10:37:08.721: NAT: s=10.8.0.2->80.122.174.90, d=8.8.8.8 [1988]
.Jul 14 10:37:08.721: NAT: s=10.8.0.1, d=80.122.174.90->10.8.0.2 [54687]
.Jul 14 10:37:08.809: NAT*: s=8.8.8.8, d=80.122.174.90->10.8.0.1 [20544]
.Jul 14 10:37:08.809: NAT: s=10.8.0.1->80.122.174.90, d=8.8.8.8 [61020]
.Jul 14 10:37:09.433: NAT*: s=8.8.8.8, d=80.122.174.90->10.8.0.1 [20545]
.Jul 14 10:37:09.433: NAT: s=10.8.0.1->80.122.174.90, d=8.8.8.8 [61021]!
Success rate is 100 percent (5/5), round-trip min/avg/max = 588/622/668 ms
If I ping 8.8.8.8 from my notebook.
As you can see by yourself the router translates packets sent to destination 8.8.8.8 with source address 10.8.0.2 to 80.122.174.90. But the router does not receive the backward icmp reply with source 8.8.8.8. Instead of it the router translates the packet with the source ip addr 10.8.0.1.
If I ping 8.8.8.8 source Vlan 155 (ip addr 10.8.0.1) directly from the router CLI everything is looking ok.
Laurent.
