07-08-2010 03:16 PM
Hi All,
Is there any way I can see spanning tree configuration for all the switches we have on our networks in Ciscoworks.
Waiting for your kind reply.
Thanks in advance
samir
Solved! Go to Solution.
07-08-2010 04:49 PM
This can be done from within Campus Manager's Topology Services. Open up the LAN Edge View map, and you should seesome switch clouds on the map. If you drill into one of the clouds, you should see a Spanning Tree option in the right-hand tree. If you expand this, you can visualize the spanning tree for MISTP or even for each VLAN.
07-08-2010 04:49 PM
