ASA5520 for Dummies Question...
Jul 8th, 2010
I'm rather a dummy with the ASA5520 but the more I play with it the more I like it.
I'm a bit in a hurry and need to 'quickly' change usernames and passwords on multiple 'wanvpn's
Can someone post the CLI commands that I'd use to do this?  In a step-by-step commands for dummies format
Just to let you know my skill level, I'm familiar enough with the unit to log into it, go into EXEC mode but can't find the command
to get to the:
hostname(config-group-policy)# webvpn
... prompt that it seems all documentation says I need to be at to issue the commands.
I'm probably missing something and was hoping someone would help.
I'd also like to know how to change the first login pw and the EXEC password, if someone would have those commands also I'd be thrilled.
Thank you greatly!
Farrukh Haroon Thu, 07/08/2010 - 20:31
This would depend on the current AAA configuration of your device.
This would be a good place to start:
http://www.cisco.com/en/US/docs/security/asa/asa71/configuration/guide/mgaccess.html
Since you are new to the ASA, I would suggest to enable the ASDM, and do everything using the GUI.
If you need further help, please post the output of 'show run aaa' from the ASA box.
Farrukh
