New to the game and need some quick help
Jul 8th, 2010
I have been thrown our exisiting phone infrastructure and what do you know we are having some issues.
We have a new series of DID's and when they are dialed from our directory they go anywhere? Not routing to the proper extension.  Translation pattern looks good in comparison to the extensions that are working.
Cisco Unified CM Administration System version: 6.1.3.3000-1
Cisco Application Administration - 5.0(2)_Build064
Package: Unified CCX Enhanced
Dan
Jaime Valencia Thu, 07/08/2010 - 19:02
  • Cisco Employee,
  • Hall of Fame,
    2011
First thing to know is that everything that has a DN can be used for routing, so it's a good idea to look at the route plan report to find matches.
If you can't find an exact match, chances are you're hitting something with wildcards ie X, [1-2], etc
An easy way to check routing if you're new to the game is to use DNA
Cisco Unified Communications Manager Dialed Number  Analyzer Guide, Release 6.1(1)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/dna/6_1_1/bw-dna.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
