Cisco 6500 Power Supply Installation
Jul 8th, 2010
I've got a 6509E with two 3000W power supplys. I need to change one of them for a 6000w, i want to know if there is some problem if the sw works with differents powers supplys and which can be the configuration (CLI) in this case.
Thanks in advance for your help
wang baojun Thu, 07/08/2010 - 19:55
hello ,
can you post your engine parameter ?   usually that have nothing to change.
juankcs85 Thu, 07/08/2010 - 20:25
Engine parameter? i dont know what is that
Can you explain?
Is necessary any command to configure this power supply correctly?
