Attempting MPLS on my lab... having issues...
Jul 8th, 2010
I have two 3620 routers, both running IOS Version 12.3(22) and 3 2507  routers running IOS Version 12.1(20).  I am attempting to setup MPLS on  them and none of the commands show up in the routers at all. I realize that the 2500's may not be able to do MPLS but the 3620's should... any ideas??
I'm sure I'm missing something, I just don't know what it is.. thanks.
Tim
nqtran1979 Fri, 07/09/2010 - 01:00
Most propbably the IOS you've got loaded.
check out the image i've attached ... you'll need at least the SP feature set to run MPLS
