PoE and Non PoE
Answered Question
Jul 8th, 2010
Hi all,
Just want to ask if it is possible to connect a cisco PoE switch to a cisco Non PoE switch?
The core switch will be a cisco Non PoE switch while the connected switch is a cisco PoE switch.
thank you....
Correct Answer by Leo Laohoo about 6 years 6 months ago
You can disable PoE on an interface by invoking the command "power inline never".
Please don't forget to rate useful posts.  Thanks.
Overall Rating: 5 (1 ratings)
nelba_aldovino Fri, 07/09/2010 - 00:43
Is there will be no problem encountered with it?
Just want to be sure because we plan to have and implement it.
Another is there an option to disable it's PoE?
thank you
Correct Answer
Leo Laohoo Sun, 07/11/2010 - 14:50
