No more web UI acces on SPA504G
Jul 8th, 2010
Since a couple of weeks I have no more acces to web UI via the web browswr using :
http://<phoneip> and/or http:<phoneip>/admin. neither of both works.
I get a connection error from firefox.
I tried fro several palces, always the same mistake.
Problem, my phone locked itself. None of the possible passwords are working.
00 or 000 or even the station's number 202
Therefor I can't even get into the configs to make any changes on the phone.
Is there any way to solve this issue without making a factory reset?
Phone is working fine anyway. I can call and receive calls without any problems.
Thank you in adavnce for any support.
tomlim526 Fri, 07/09/2010 - 09:42
The only thing I can think of, is maybe the ip address changed on you.  If you're using dynamic ip then it may have changed.  You can check the phone ip in network settings.
