Ganesh Hariharan Fri, 07/09/2010 - 02:16
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
I want to Know about story for ACL, Route MAP, Prefix length and route Prefix any once can share with me...
An access control list (ACL) is a list of permissions defined for an object. The ACL specifies what permissions are allowed or denied to a specific object (subnet/host/TCP-UDP port/protocol).
To define the conditions based acl for redistributing routes from one routing protocol into another, or to enable policy routing, use the route-map command in global configuration mode and the match and set command in route-map configuration modes
Ip prefix-list provides the most powerful prefix based filtering mechanism. In addition to access-list functionality, ip prefix-list has prefix length range specification and sequential number specification. You can add or delete prefix based filters to arbitrary points of prefix-list using sequential number specification.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
