07-09-2010 12:58 AM - edited 03-06-2019 11:57 AM
Dear Friends,
any once can share how i can enable the VTP trap generation in switch?
it show in #sh vtp status
Solved! Go to Solution.
07-09-2010 01:42 AM
Dear Friends,
VTP trap is disabled by default. If you enable this feature, it causes an SNMP message to be generated every time a new VTP message is sent.
This example shows how to send VTP traps to the NMS:
Switch(config)# snmp-server enable traps vtp
You can verify your setting by entering the show vtp status or the show running-config privileged EXEC command.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
07-09-2010 01:42 AM
Dear Friends,
Hope to Help !!
Ganesh.H
