Outbound SIP Dialer UCCE
Jul 9th, 2010
I trying to configure outbound sip dialer in UCCE 8.0(2) using agent based campaign
Everything seem fine dialer status all active, MR PG active
After contact imported, GW begin to dial contact number but just 1 ring and call disconnected before I can pickup.
I'm not use SIP Proxy, Dialer directly connect to GW.
Here is the dial-peer configuartion I'm using
interface Loopback0
ip address 10.100.100.1 255.255.255.0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.2
no supplementary-service h450.3
supplementary-service h450.12
signaling forward none
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
sip
  bind control source-interface Loopback0
  bind media source-interface Loopback0
  rel1xx require "100rel"
dial-peer voice 2002 voip (Inbound dialpeer)
session protocol sipv2
incoming called-number .T
voice-class sip rel1xx require "100rel"
dtmf-relay rtp-nte h245-signal h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 9089 pots (Outbound dialpeer to ISDN BRI)
destination-pattern 08........
port 0/1/1
prefix 08
I'm trying to debug, it seem that dialer connect the call and just disconnect with normal call clearing
Jul  9 06:18:06.373: ISDN BR0/1/1 Q931: Sending SETUP  callref = 0x002B callID = 0x8030 switch = basic-net3 interface = User
Jul  9 06:18:06.373: ISDN BR0/1/1 Q931: TX -> SETUP pd = 8  callref = 0x2B
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0x81
                Preferred, B1
        Called Party Number i = 0x80, '0892334314'
                Plan:Unknown, Type:Unknown
Jul  9 06:18:06.621: ISDN BR0/1/1 Q931: RX <- SETUP_ACK pd = 8  callref = 0xAB
        Channel ID i = 0x89
                Exclusive, B1
Jul  9 06:18:10.153: ISDN BR0/1/1 Q931: TX -> DISCONNECT pd = 8  callref = 0x2B
        Cause i = 0x8090 - Normal call clearing
Jul  9 06:18:10.253: ISDN BR0/1/1 Q931: RX <- RELEASE pd = 8  callref = 0xAB
Jul  9 06:18:10.257: ISDN BR0/1/1 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x2B
Jul  9 06:18:10.465: ISDN BR0/1/1 Q931: Sending SETUP  callref = 0x002C callID = 0x8031 switch = basic-net3 interface = User
Please help me!!!
karthikayyappan10 Mon, 11/22/2010 - 21:47
Hey any one can guide me to integrate SIP dialer to UCCE 8.0???
I need to know how to configure it in the UCCE 8.0.
If any documents for configuring SIP dialer in UCCE8.0 kindly share the link..
I need the procedures and steps..
david.macias Fri, 03/25/2011 - 15:12
We're expericing something very similar where we see a cancel from the dialer, did anyone get a solution?
Thank you,
david
rhobab Thu, 07/07/2011 - 08:59
Did anyone get a solution for this. I have managed to see from the dialer logs that it is sending a cancel because it is giving  a  NODIALTONE error. In my case we are using a CUBE.
thanks
Victor
Mark Pareja Fri, 12/16/2011 - 14:08
So from your config I see a Dial Peer for the incomming call from Dialer, and a uotbound Pots port but after the connect is established what do you intend on doing with the call ?
I would expect a Dial peer to deliver the call to an agent via CUCM sip trunk or a Dial Peer with a CVP label to route to a VRU script.
hassanalirazi Tue, 12/20/2011 - 22:12
We have faced this issue before and you need to create a route, SIP dialer route for that number.
for eg. the number for agent based campaign is 6111 u need to create a route for dialer for this number in the config manager.
Hassan
hassanalirazi Tue, 12/20/2011 - 22:49
You need to create a label for the campaign DN u created with RC of dialer and NEtwork VRU shd be CVP VRU.
Hassan
