configure restriction list for outgoing calls in srst
Jul 9th, 2010
a customer has a situation like following:
10 phones: the first 5 of it can call  to all destinations worldwide, the last 5 can only make intern calls and call
entries from a list like this:
*1123
*1234
*1456
and so on.
This entries are translated via translation-pattern in predefined external numbers like 00151445626354 for *1123 and so on.
The list has 130 entries.
So the 5 phones can make internal call, emergency calls and via *1-List calls to predefined external numbers.
In CUCM works very well.
I will configure this for SRST-Case.
I configured cor lists, so that the last 5 phones cannot make external calls.Here the cor list should be named "Restricted".
The calls for the list:
I found a solution with number expansion
num-exp \*1123 00151445626354
I created a pots dial-peer for cor list "Restricted" with destination-pattern 0T.
It works, but now the user can call everywhere with the prefix 0. So I have to configure 130 pots peers for cor list "Restricted" , each for every entry ??
Is there a simplier way?
