difficulty understanding bridge-domains
Jul 9th, 2010
Hi All,
Im hoping you can help me out here.  Its been a while since ive  had to configure Cisco nodes.
This is what im trying to achieve.
A Node with multiple interfaces sharing the same subnet terminating on a Cisco 7609 equipped with ES+ cards.  So what im hoping to achieve is to terminate these interfaces in a BVI fashion.
Previously i remember that we could assign an interface to a bridge-group and then assign a BVI interface for that bridge group and add the BVI interface to a VRF.
Now that the bridge-domain command has entered, how would i do this?
If i assign multiple interfaces to bridge-domain 10 for example, where would i assign an IP for that particular vlan?
chanukavitanachy Fri, 07/09/2010 - 03:29
Just to Follow up,
Can I do this?
interface GigabitEthernet1/1
service instance 10 ethernet
  encapsulation dot1q 10
  bridge-domain 10
interface GigabitEthernet1/2
  bridge-domain 10
interface Vlan10
ip vrf forwarding BOB
ip address 1.1.1.1 255.255.255.0
Cheers!
Ganesh Hariharan Sat, 07/10/2010 - 08:40
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Just to Follow up,
Can I do this?
  bridge-domain 10
  bridge-domain 10
interface Vlan10
Cheers!
Check out the below link on BVI on router interface hope to help !!
http://www.cisco.com/en/US/tech/tk389/tk815/technologies_tech_note09186a0080094663.shtml
Ganesh.H
chanukavitanachy Sun, 07/11/2010 - 19:16
Hi Ganesh,
This was the previous way to do this, but bridge groups are now done away with it seems on the 7600's.  I now need to use bridge-domains to sort this out.
