Problem manually loading certificate loading vpn spa device certificate on catalyst 6500
Jul 9th, 2010
Dear colleagues,
I wonder if someone out there can point in the right direction.
I have the IPSEC VPN SPA running of a CAT6513 switch and I am wanting to use certificates for authenitication but somehow I can't seem to complete the process successfully:
I have gone through the following steps:
1. crypto key generate rsa general keys
Created my keys with modulus 2048.
2. Create the trust point
crypto ca trustpoint mysite
3. Generate CSR
crypto ca enroll mysite
4.Create my cer from the csr created above.
5. Load the CA root certificate
Loads succesfully
CA loaded
6. Load server certificate(VPN SPA)
crypto ca import mysite certificate
I then get the following error:
Failed to parse or verify imported certificate?
The CA has a modulus of 4096 bits and I used to generate the key for signing with the CA.
Could that cause problems?
Can someone please point out where I might be going wrong?
Thanks and regards,
Gibson Moses
Marcin Latosiewicz Fri, 07/09/2010 - 03:45
  • Cisco Employee,
Hello there,
Can you please share with us decode of the new certificate?
One thing I was recently dealing with was Signature Algorithm field.
But maybe you can do crypto pki debugs while you apply the cert?
deb cry pki m
deb cry pki t
and do share software version on cat6k.
Not that PKI component is not dependand on VPN SPA.
Marcin
