Need help with ADSL
Jul 9th, 2010
Hello
I have cisco SOHO97 (software version 12.4) and I can not connect to ADSL, I try with this configuration but it doesn't work :
ATM protocol: PPPoE
Ip Address: dynamic
VPI/VCI: 8/35
vpdn enable
vpdn-group pppoe
  request-dialin
   protocol pppoe
interface Dialer1
  mtu 1492
  ip address negotiated
  ip nat outside
  encapsulation ppp
   dialer pool 1
  ppp authentication pap callin
  ppp pap sent-username <username> password <password>
interface ATM0
  no ip address
  no ip mroute-cache
   no atm ilmi-keepalive
  dsl operating-mode auto
  pvc 8/35
   encapsulation aal5snap
   pppoe-client dial-pool-number 1
  no shutdown
interface Ethernet0
  ip address <IP> <mask>
  ip nat inside
  no ip mroute-cache
  ip tcp adjust-mss 1452
  no shutdown
ip nat inside source list 1 interface Dialer1 overload
access-list 1 permit any
I set my PC gateway to Ethernet0 IP
Please help me
johnlloyd_13 Fri, 07/09/2010 - 06:14
  • Blue, 1500 points or more
can try adding a static default route: ip route 0.0.0.0 0.0.0.0 Dialer1
also, may i suggest using extended ACL and add PAT command below:
access-list 101 permit ip any
ip nat inside source list 101 interface Dialer1 overload
KnezevicM Wed, 07/14/2010 - 08:06
Now I know what is the problem. I configure my soho97 like this:
interface ATM0
no ip address
pvc 8/35
interface Dialer0
mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
no cdp enable
ppp pap sent-username xxx password xxx
and when I enable ATM0 a get these messages:
*Mar 1 00:03:56.635: %LINK-3-UPDOWN: Interface ATM0, changed state to up
*Mar 1 00:03:57.635: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0, chan
ged state to up
*Mar 1 00:03:57.947: %DIALER-6-BIND: Interface Vi1 bound to profile Di1
*Mar 1 00:03:57.975: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state t
o up
*Mar 1 00:04:00.431: %DIALER-6-UNBIND: Interface Vi1 unbound from profile Di1
*Mar 1 00:04:00.435: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state t
o down
*Mar 1 00:04:23.591: %DIALER-6-BIND: Interface Vi1 bound to profile Di1
*Mar 1 00:04:23.595: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state t
o up
*Mar 1 00:04:26.063: %DIALER-6-UNBIND: Interface Vi1 unbound from profile Di1
*Mar 1 00:04:26.067: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state t
o down
What can be problem ???
davidsudjiman Thu, 07/15/2010 - 01:17
Milos, You can use "debug ppp negotiation" and "debug dialer events" to check whether the ISP is acknowledging your authentication.
rgds, dsu
KnezevicM Thu, 07/15/2010 - 05:50
Ok now I know what is the problem. I try with another username and pass ( with 7 characters ) and it works, but when I enter my username and pass (with 15 characters) it say Access Denied.
