UCCX 8 HolidayCheck with xml
Answered Question
Jul 9th, 2010
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
we used to use a holiday check script that check an XML file to return a true or false value for holidies
however this one is not working with the new UCCX 8 as this version is Linux OS and i think there is some differences in the path or access to the xml file i have included a copy of the script with the xml file any idea or help how we can get this working with CCX 8 will be appriciated
Thank you
Overall Rating: 5 (1 ratings)
andreas.eichhor... Fri, 07/09/2010 - 06:57
we changed our Holdiay Scripts from XML-Files access to Repository access. You can upload a document in the repository (database) and after that you have to change the the script.
Best regards
Andreas
Marwan ALshawi Fri, 07/09/2010 - 18:10
Hi There
i already did uploaded the xml through the GUI to the server
but i am getting the error in the snapshot
if you have a working holiday check script to share it here will be great at least i can compare the differences
Thank you
Marwan ALshawi Fri, 07/09/2010 - 18:42
thank you i will try it
Marwan ALshawi Mon, 07/12/2010 - 03:50
thank you worked
But the XML file and the script use date format as mm/dd/yy
while i want it as  dd/mm/yy
i cahnge the XML file to this format also i change in the script the format matching as bellow but it is not working with this format any idea how to make this script to work with the xml format as dd/mm/yy !!
(dtTodaysDate.date == dtHolidayDate.date) && (dtTodaysDate.month == dtHolidayDate.month) && (dtTodaysDate.year == dtHolidayDate.year)
Thank you
d.pennington Mon, 07/12/2010 - 13:07
what folder are you uploading your XML files to?
default
en
en_US
mscaramelli Thu, 10/28/2010 - 05:20
have you solved the problem ? I've got the same issue ! Thanks in advance
