cisco security manager. cannot change interface roles on context`s inside and outside interface
Within cisco security manager I cannot change the interface role on my context`s inside and outside interfaces.  I have named them inside_vlanxxx and outside_vlanxxx. And then discovered my contexts.   The only role that applies automatically is All-interfaces and I cannot seem to change this to internal or external.  Is there anyway I can change this role without having to change my contexts interface names and re-discovering?  I find it ridiculous that it will only recognise inside and outside as key words when you can name your context interfaces anything you want.  Many thanks in advance for any advise
1 vote
Panos Kampanakis Fri, 07/09/2010 - 09:45
Please provide snapsnots of the CSM screen you are referring to.
Are you in the system context, or the context theselves?
CSM should be able to change the name (nameif command).
ian.olivier1 Sun, 11/15/2015 - 02:14
Hi Gary
Did you resolve this issue. I am having the same thing.
How did you resolve it?
