If you have changed the IP address and have modified the Enterprise
Parameters, then you will need to reset the IP phones so they pull the new
parameter. You can test this by editing a single phone. Go to the
Enterprise Parameters. Copy the URL for the directories. Then go to an IP
phone configuration. Scroll down on the device configuration page until you
see the directories URL on the device. Paste the URL you copied. Ensure
that the proper address is in the link pasted. Save and then reset the
phone. Check the directories from that particular phone.
Now, the above steps are for pre-7x and 7x with external or mixed service
provisioning. If you are running 7x with the default provisioning method,
then you wouldn't have a problem with IP address changes. But, just so we
know. What version of callmanager are you running?
HTH.
Bill
Please remember to rate helpful posts using the stars below.
On 7/9/10 11:56 AM, "coopdea@yahoo.com"
