Two DHCPs, one is slow to send the offer
Jul 9th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
Hello, I have a small issue about DHCP, I need two servers of DHCP.
1 - Provide by Switch Cisco  range 172.17.52.0
2 - Provide by Windows Server range 10.10.10.0
Everything works ok, but when I have a Computer using vlan 101 (at interface GigabitEthernet2/0/1) the DHCP is to slow, at debug mode I can read no dhcp pool for vlan 101,
then I see forward to 10.10.10.253, but this process is to slow, my computer need about 30 seconds (at wireshark I watch about 10 lines of 0.0.0.0 255.255.255.255 resquest form the computer).
The configuration of the switch:
ip dhcp excluded-address 172.17.52.254
service dhcp
ip dhcp pool Wifi-Guest
   network 172.17.52.0 255.255.255.0
   default-router 172.17.52.254
   dns-server 8.8.8.8 4.2.2.2
interface Vlan100
description ### Wireless - SSID ###
ip address 172.17.52.254 255.255.255.0
interface Vlan101
ip address 10.10.10.254 255.255.255.0
ip helper-address 10.10.10.253
switchport mode access
switchport access vlan 101
spanning-tree portfast
spanning-tree bpduguard enable
My point is, how to disable DHCP server to vlan 101, I have try this:
ip dhcp excluded-address 10.10.10.1 10.10.10.254
but didn’t work... the speed is slow.
Also try to
interface Vlan101
no ip dhcp-server... but this command dont work obligate to "no ip dhcp server use subscriber-id"
Anyone have ideas to block or disable dhcp to vlan 101 on the switch dhcp server?.
Thanks in advance
Jon Marshall Fri, 07/09/2010 - 10:06
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
interface vlan 101
no ip helper-address 10.10.10.253
