Change IP Address ACS 4.2 Appliance
Jul 9th, 2010
I have an ACS 4.2 Appliance integrated with AD and CA in Windows 2K3 both of then working OK and Remote Agent, but we want to change the IP Address of the ACS 4.2 Appliance, What is the procedure to do this? have i install the certified again? i know that certified depend of hostname and ip address.
Thank You
Álvaro
Ganesh Hariharan Sat, 07/10/2010 - 09:18
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Thank You
Álvaro
Hi Alvaro,
Best take the  serial console of the ACS Appliance and type set ip and follow the procedure to change the ip address
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_solution_engine/4.2/installation/guide/solution_engine/admap.html
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
