Simple routing issue
Jul 9th, 2010
Hi All
I've configured a network with PE's and CE's what I have is EIGRP running between PE's and EBGP between PE and CE's. can't reach router loopback address of other CE's. Routing on the PE's works to all locations without a problem. I have DMVPN running between PE's but this is'nt impacting the routing in anyway because the PE's can reach other and all LAN and loopback subnets.
Between CE and PE i redistribute EIGRP into BGP and BGP into EIGRP.
The problem seems to be the routing between CE-CE.
Exampls
ping from
CE1-CE3
CE-1-CE2
from CE-1 pinging loopback 192.168.3.1
from CE-1 pinging loopback 192.168.10.1
All other routing works well.
Can anyone point me in the right direction configurations attached,
All i need is to have full routing from the CE's. I don't know why the PE's are dropping packets destined for other CE's.
Please find configs attached.
Chetan Kumar Ress Sun, 07/11/2010 - 11:33
  • Silver, 250 points or more
Hi Carl
Here the senario that you post i think you are trying to run VRF-Lite over the PE's.
You have configured TEST_VRF1 for Cust & configured same VRF for DMVPN Tunnel. althrough  should i consider that you want to run  Excrypted traffic of that customer over PE's.
Here in you tunnel config please check :
interface Tunnel1
ip vrf forwarding TEST_VRF1
ip address 192.168.4.1 255.255.255.0
no ip redirects
ip mtu 1532
no ip next-hop-self eigrp 90
ip nhrp map multicast dynamic
ip nhrp network-id 123
no ip split-horizon eigrp 90
tunnel source FastEthernet1/0
tunnel mode gre multipoint
tunnel protection ipsec profile Secure_Tunnel
interface FastEthernet1/0
description *** Link to Core Switch ******
ip address 192.168.2.26 255.255.255.0
duplex auto
speed auto
Tunnel source is fa1/0 & That tunnel is in VRF , But the source traffic is in Global routing table. So i think that it will not work , Config you VRF to use global routing table so that the tunnel source will work properly .
Note : I have not simulated the senario . But still in overview i think is can be issue. Please check
Chetan Kumar
Mohamed Sobair Sun, 07/11/2010 - 07:22
  • Gold, 750 points or more
Carl,
In order for the PE to import all CE routes which was previously learned by bgp between the PE-CE, you will still need bgp between the PEs rather than Eigrp or any other routing protocol .
The fact is that the Route-targets are only carried by BGP protocol with the extended community, your redistribution between Eigrp and BGP will not carry those route targets and would thefore not carry the routes.
I suggest you have a VPNv4 session between all your PEs . This should solve your problem.
Another question is that why do you have DMVPN between PEs rather than your CEs?
Mohamed
