Help on Installing WRVS4400N
Jul 9th, 2010
We just purchased WRVS4400 for our church
network, we have 5 static IP one was configured to the router, then we have a server windows 2003 that will do streaming video but I not able to use the others Static IP so I can put one to the server. Any suggestion on the set up...
LAN IP 192.168
WAN IP 209.172.xxxx provided by our ISP provider
MODE   Gateway
DMZ   Off
Te-Kai Liu Fri, 07/09/2010 - 14:12
  • Gold, 750 points or more
WRVS4400N only supports one public IP address, which is the WAN IP of the router. If you need to support multiple public IP addresses, you would need products such as RV120W or RV042+WAP4410N, or SA520W.
Tiya Rabb Fri, 07/09/2010 - 20:34
Maybe port forwarding could be an option if you have the ability to specify a
port to be used for your video streaming as an alternative to 1-to-1 NAT. Hope this helps!
