CUCM Virtual Machine
Answered Question
Jul 9th, 2010
I'm looking into adding a CUCM Subscriber into our cluster as a virtual machine in VMWare ESX 4.  I have two questions.
1.  Is it okay to have a couple of physical CUCM's and add a virtual subscriber to that cluster?
2.  How does the licensing work for that?  Is there just a CUCM software part number for ESX installs?  If so, what is the part number?
Correct Answer by Jonathan Schulenberg about 6 years 11 months ago
No. UCM 8.x will only be supported on Cisco UCS hardware. Third-party host support is a ways off.
Correct Answer by Jaime Valencia about 6 years 11 months ago
Since we do not support anything other than CUCM 8.0(2) in VMWare we do not sell anything associated to this scenario.
You would need to buy any associated PNs as if it was a regular MCS install.
The only thing before 8.0(2) we support on VMWare are the NFR kits.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Correct Answer by Brandon Buffin about 6 years 11 months ago
Virtualization is only supported with CUCM 8.x and only on Cisco UCS servers. It is possible to install CUCM in a VM outside of these parameters, but it will not be supported by Cisco.
Hope this helps.
Brandon
Overall Rating: 5 (3 ratings)
Correct Answer
Brandon Buffin Fri, 07/09/2010 - 13:34
  • Purple, 4500 points or more
Hope this helps.
Brandon
jeffkelso Fri, 07/09/2010 - 13:39
I understand that it isn't supported, but will the above scenario work?  If so, what is the part number?  Do I just a purchase a CUCM server seat?
Correct Answer
Jaime Valencia Fri, 07/09/2010 - 14:16
  • Cisco Employee,
  • Hall of Fame,
    2011
java
jeffkelso Fri, 07/09/2010 - 14:21
8.0(2c) is out.  We are about to move to it.  Will it eventually have specific PN for VM loads?
Correct Answer
Jonathan Schulenberg Sun, 07/11/2010 - 07:18
  • Cisco Designated VIP,
    2017 IP Telephony
Related Content
