Outbound Caller ID is showing Unknown Number
sienz.sienz
We have a problem where when we call from our desk phones (CUCM) to 3G wireless phones, the wireless phone will receive caller ID as “unknown number”. We contacted our telco/PRI provider to check the digit that we are sending and it was ok.
Then we contacted AT&T and made some tests and found out that the “unknown number” is only happening to 3G wireless user and it is only for local number (7-digit dialing)
AT&T said that “The Calling Party Number parameter as it is sent in from the office number is not set according to standards. The Numbering Plan is Unknown and should be ISDN/Telephony. In addition, the Screening Indicator is Reserved - User Provided,Not Screened and  it should be Network Provided or "User-Provided - Screened and Passed”
Questions:
Is this some configuration in our system or with telco/PRI provider?
sienz
11 Replies 11
Jaime Valencia
You can set that under your PRI/H323 config and also using calling/called party transformation patterns.
Telcos can also override and change it, but you need to start by sending it correctly from CUCM
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Thanks Java,
Any documentation on making changing on our gateway?
I just did debug q931 and here is the result if anyone can help: (Thanks)
Jul  9 21:28:04.070: ISDN Se0/0/0:23 Q931: TX -> PROGRESS pd = 8  callref = 0xF865
        Cause i = 0x8181 - Unallocated/unassigned number
        Progress Ind i = 0x8188 - In-band info or appropriate now available
*Jul  9 21:28:06.798: ISDN Se0/0/0:23 EVENT: process_pri_call: call id 0xB725, number 2688622, Guid 0082A73AAE3E, speed 0, call type VOICE, redial No, CSM call No, pdata Yes
*Jul  9 21:28:06.798: ISDN Se0/0/0:23 Q931: pak_private_number: Invalid type/plan 0x0 0x0 may be overriden; sw-type 13
*Jul  9 21:28:06.802: ISDN Se0/0/0:23 Q931: Applying typeplan for sw-type 0xD is 0x0 0x0, Called num 2688622
*Jul  9 21:28:06.802: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8  callref = 0x376E
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98393
                Exclusive, Channel 19
        Calling Party Number i = 0x0081, '7028582580'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '2688622'
*Jul  9 21:28:07.054: ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0xB76E
*Jul  9 21:28:07.054: ISDN Se0/0/0:23 EVENT: process_rxstate: ces/callid 1/0xB725 calltype 2 CALL_PROCEEDING
*Jul  9 21:28:08.798: ISDN Se0/0/0:23 Q931: RX <- PROGRESS pd = 8  callref = 0xB76E
        Progress Ind i = 0x8288 - In-band info or appropriate now available
*Jul  9 21:28:08.798: ISDN Se0/0/0:23 EVENT: process_rxstate: ces/callid 1/0xB725 calltype 2 CALL_PROGRESS
*Jul  9 21:28:08.830: ISDN Se0/0/0:23 Q931: RX <- DISCONNECT pd = 8  callref = 0x7865
        Cause i = 0x8090 - Normal call clearing
*Jul  9 21:28:08.830: ISDN Se0/0/0:23 EVENT: process_rxstate: ces/callid 1/0x4797 calltype 2 CALL_DISC
*Jul  9 21:28:08.830: ISDN Se0/0/0:23 Q931: TX -> RELEASE pd = 8  callref = 0xF865
*Jul  9 21:28:08.854: ISDN Se0/0/0:23 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x7865
*Jul  9 21:28:08.854: ISDN Se0/0/0:23 EVENT: process_rxstate: ces/callid 1/0x4797 calltype 2 CALL_CLEARED
H323
Call Routing Information - Outbound Calls
MGCP
On left hand from above there is CALLING party transformations if you need them as well.
java
java
Its a telco issue show this to them
if we send the calling party number no amount of config will fix this issue since we already send the calling number
asharsidd
It's entirely possible that even sending calling party number the provider doesn't accept it if you are not sending the type. Please confirm from your provdier what type they would like to see.
Thanks all for the input, especially Javalenc.
The Calling party Number that we are sending is correct according to our telco provider but AT&T (as the receiver) said that Screening Indicator and the Numbering Plan is not acceptable to their 3G network. AT&T also confirm that they receive a good phone number but the Screening Indicator and the Numbering Plan is not acceptable.
I will try changing it on Monday based on Javalence Document.
They may insist that you set plan/type to their spec, but the Screening Indicator is already correctly set to "user-provided, verified and passed". Note also the Presentation Indicator is correctly set.
http://www.acacia-net.com/wwwcla/protocol/q931_ie.htm#ie_field_screening_indicator_cgpn
sienz.sienz
Thank you for checking it and for the link p.bevilacqua.
I will verify it again on Monday.
I guess, it may come down to "The Numbering Plan is Unknown and should be ISDN/Telephony"
Also if the screening indicator is already correctly set, the telco may override it so I will need to check to our telco provider what they are sending.
Thanks again
sienz
You will see that is easily solved.
What I do in similar cases, is to fix it from home during the weekend, then show up late at the office on Monday explaining how the issues took most of the day talking to telcos.
We found the issue,  It is in the gateway.  Someone put this on interface Serial0/0/0:23, it is fixed after it is removed
isdn map address . plan unknown type unknown.
Thanks all
Cery good, please remember to rate useful posts clicking on the stars below.
