DMA migration from CM 4.2.3 to CM 7.1.3 unexpected hostnames
We migrated over to CM 7 a couple of weeks ago using DMA from CM 4.2.3.  When I do a Show>Cluster from the OS Administration page I see the following:
qpub
qsub1.localdomain.com
qsub2.localdomain.com
qsub3
Is it possible that when CM 4x was installed they attempted to join a domain?  There was a DMA Warning that stated that the LDAP Operation Failed.  I opened a TAC case and was told to ignore it.  Is this cosmetic or should I be concerned?
-T
William Bell Fri, 07/09/2010 - 16:55
  • Purple, 4500 points or more
This wouldn't be related to joining a domain or LDAP. I am not sure why the
servers would show up with a mixture of fully qualified domain names versus
host names. I do not think this would pose a problem as long as forward and
reverse domaind lookups work between all cluster nodes. To check whether
this is a problem. I would do the following (on each cluster node):
1. Connect via SSH to the CLI (or KVM console if you prefer)
2. Run command: show network cluster
3. Run command: show tech network hosts
4. Run command: utils diagnose module validate network
The last command is key. If you see a failure here, I would contact Tac and
let them know that it may be more than cosmetic. With the other two
commands you are looking for further inconsistencies and anything that
appears invalid. Post the output if you prefer.
HTH.
Bill
Please remember to rate helpful posts.
On 7/9/10 7:12 PM, "[email protected]"
