VPN PORTS TO OPEN OUTBOUND
Jul 10th, 2010
I have a task to open VPN ports outbound only. Please help me on how to configure the firewall to access VPN. I want to open ports of VPN only where will I apply the ports in the firewall.
thank you and best regards
Edwin
Marcin Latosiewicz Sat, 07/10/2010 - 06:48
  • Cisco Employee,
I understand that you mean IPsec VPN? And not ANY kind of VPN?
Here's a list.
udp/500 - IKE
udp/4500 - IKE NAT-T
ESP
AH
(IPsec over TCP can use on top a verity of ports ... usually tcp/10000)
ericohermoso Sat, 07/10/2010 - 07:06
Thank you for the reply. I am not so good about VPN. An Application for remote access vpn as configured in firewall, I'm not sure if it is IPSEC VPN. I will try to open this two port, Anyway, Please, what is equivalent port number of esp and AH.
thank you and best regards,
Edwin
