Can i use MGCP gw as a h323 gw in the same time ???
Jul 10th, 2010
Hi ,
as you can see in the subject I have a mcgp gw with PRI ISDN card and it is used by UC1 system with CUCM. Now, I want to use this gw/PRI with an another UC2 system (uc500), but in this situation gw is going to be h.323.
Since gw has just one LAN interface , can i designate this interface to be h.323 interface without impact to UC1 (MGCP) ???
Thank you...
auppal Sat, 07/10/2010 - 09:23
  • Cisco Employee,
you cannot have 1 PRI do both mgcp and h323 once the l2 is backhauled to CUCM in mgcp there is no more h323 on that gw. However you can have the router do 2 protocols simultaneously for eg you can have 2 PRI's one doing MGCP and 1 doing h323
IdontNeedNick Sat, 07/10/2010 - 12:53
Thank you auppal for your quick response,
I've connected UC500 with CUCM UC system so UC2 can use PRI ISDN link. Because I am not familiar with MGCP i just wanted to check si this  configuration using h323 possible...
auppal Sat, 07/10/2010 - 16:32
  • Cisco Employee,
its easier to correlate deb ephone mac-address with deb voip ccapi def as supposed to only look at deb ephone
mac-address
